Our 1950s house came with an instruction manual.
October 27th, 2008 by JeffOur house came with an instruction manual that I recently found tucked behind some insulation in the garage. We live in a planned community built in San Francisco in the mid 1950s. This particular house was built in 1956 by Sunstream Homes, so the manual is over 52 years old.
The house also still has the original electric stove, but that’s another story.
What an awesome read, check out the fullsize version.
The new home that you have purchased has to be adjusted to normal use, just the same as any new article. The following list of helpful hints and suggestions will be of great aid to you in prolonging the life of your home, besides saving you must expense in later years. You will get the most satisfactory results and the greatest enjoyment from your SUNSTREAM HOME by observing various items that are listed below:
Tags: san francisco, sunstream
I like item #20, looks like they accidentally went from 19-21 and then added 20 at the end.
#30 is my clear favorite.
30 … Do not use water or GASOLINE (!!!) on hardwood floors.
Sunstream sounds like it should be the name of a Transformer… Which begs the question: Autobot or Decepticon?
