Rigol DS1052E 50MHz to 100MHz scope hack
March 11th, 2010 by Jeff
Hack a Day posted yesterday that a guy named Ross turned his 50MHz Rigol DS1052E into a 100MHz capable instrument by removing part of a lowpass filter on the analog inputs.
I think it remains to be seen whether there are any other mods required to make this work like a real DS1102E (ie. does the 1052E firmware limit the minimum horizontal timescale?) but this is hardware hacking at its finest!
Read more about it on the EEVblog forums.
Tags: , , , ,
8 Responses to “Rigol DS1052E 50MHz to 100MHz scope hack”
  1. Dimlow says:
    This Hack is now obsolete, there is now a simple software hack.
  2. Dimlow says:
    Here is the detail for you.
    Connect a straight through serial cable to scope and computer.
    Open up a terminal program on the PC, set to 9600 baud 8 data bits, no parity,1 stop bit, no flow control, set it to echo back what you type and send only Linefeeds.
    to test coms send :IO:TEST testing
    it should come back with “testing”
    great, now to hack your scope
    :INFO:MODEL DS1102E
    • Dimlow says:
      OOPS, HIT THE SUBMIT BEFORE I WAS FINISHED!
      Here is the rest
      No change the serial (X is your own serial)
      :INFO:SERIAL DS1EBXXXXXXXXX
      Switch off the scope then back on and calibrate.
      Job Done, you now have a 100Mhz DS1102E
  3. anli says:
    I have tried this software hack with DS1022C without success. Does it mean there isn’t a way to apply the hack to this model?
  4. Jeff says:
    Anli – I am not aware of a hack for the DS1022C. I don’t know if the same weakness in the 1052E applies to any other scopes. I think the DS1052E was the first target because it is common and cheap.
    More info about the software hack is here:
    http://oreskovic.me/wp/?p=27
  5. anli says:
    Jeff,
    Thanks, I have read that blog.
    At any case it seems like DS1022C (BTW, it is older and cheaper) has another “right way” (or has not it at all). Say, :INFO:MODEL? returns nothing, ‘:IO:TEST ABC’ also returns nothing (*IDN?, :INFO:SERIAL? do work – so connection is OK).
  6. Figo says:
    Hi there,
    I’m glad to share a site to buy rigol ds1052e: http://www.dealexcel.com/rigol-ds-1052e-50-mhz-2-channel-digital-oscilloscope_p363.html
    I almost could not believe its price is US$359.99 including delivery, but i still ordered one.
    Ps, the package is shipped via EMS Express, i received it 7days later, Los Angeles, California
