Is it okay to distance the tube from the board itself (using wire appropriately rated for the voltage)?
I have a constrained amount of space where the tube needs to be (on the surface of a fusor chamber) and I'd like to put the board in a remote location from the tube itself.
If so, what is a reasonable length for the wires?
Cable to tube?
Re: Cable to tube?
This will work for short cables in electrically quiet environments.
The design of the kit puts the tube cathode at a potential above ground, so unless you use twinax cable, it's not possible to shield the cable (coax won't work, since you can't ground the shield). A few inches should be fine, but I would try to keep the cable as short as possible.
Re: Cable to tube?
Thanks for the reply, Jeff.
Electrically quiet environment will be tough; the tubes are about 6 inches away from a 30kv discharge in a vacuum.
I'll give twinax a try and share the results!
Thank you.
Thank you.
