I wondered about using the Random numbers on the computer from the DMAD,
what I found is that most terminal emulators will display something unreadable
from the DMAD when in random number mode, if you find a terminal emulator that
can view and save the data has HEX, that file then then be converted to decimal.
I am looking into a better way, but here is how I am doing it now.
I use a program called "Terminal", I set it to "
HEX" and then press "
StartLog",
I let it run for how ever long I want, and then press "
StopLog", I open that
file in a program called "Replace Pioneer" and click on "
Replace" then
Replace by template" then "
Binary/Octet/Decimal/Hex Conversion" then
Convert text from Hex to Decimal", you then select your "
Input file" and
Output File" and click on "
Replace"
Here is a sample
Before conversion
Terminal log file
Date: 12/18/2011 - 2:52:55 PM
35 3A 04 10 1E 0E 12 04 10 08 16 0D 16 1C 3A 06
19 38 0D 08 10 05 25 39 19 21 2C 06 2C 0B 18 08
27 06 38 01 22 3C 3B 0F 1C 1A 1A 2D 25 22 19 17
05 1F 27 16 04 36 13 10 23 09 0C 05 18 35 07 26
08 1C 08 01 1B 0B 05 32 1B 17 34 01 05 35 10 1F
0E 05 1D 1F 19 03 0F 04 0C 3B 06 17 09 08 06 17
0C 1C 01 0F 0F 07 20 28 3C 31 0D 04 17 3D 2E 17
24 26 0A 05 0B 04 04 0B 0E 05 16 2F 24 18 0A 1A
30 35 14 09 02 2A 07 17 19 02 08 0A 2E 05 01 17
2D 12 1E 13 1D 03 01 32 32 0F 15 0A 1B 1B 26 18
33 1B 09 0C 0B 06 17 3F 18 3C 3A 3A 3C 0F 1E 20
08 21 33 2B 01 0E 11 3F 02 2E 1B 3E 26 0D 21 0C
05 22 03 2B 36 21 1B 20 07 06 3F 16 24 30 09 07
1D 15 11 37 21 02 2C 0C 08 07 0F 27 14 25 07 02
19 0A 0D 04 04 1B 37 1E 11
Date: 12/18/2011 - 2:53:32 PM
End log file
After Conversion
Terminal log file
53 58 4 16 30 14 18 4 16 8 22 13 22 28 58 6
25 56 13 8 16 5 37 57 25 33 44 6 44 11 24 8
39 6 56 1 34 60 59 15 28 26 26 45 37 34 25 23
5 31 39 22 4 54 19 16 35 9 12 5 24 53 7 38
8 28 8 1 27 11 5 50 27 23 52 1 5 53 16 31
14 5 29 31 25 3 15 4 12 59 6 23 9 8 6 23
12 28 1 15 15 7 32 40 60 49 13 4 23 61 46 23
36 38 10 5 11 4 4 11 14 5 22 47 36 24 10 26
48 53 20 9 2 42 7 23 25 2 8 10 46 5 1 23
45 18 30 19 29 3 1 50 50 15 21 10 27 27 38 24
51 27 9 12 11 6 23 63 24 60 58 58 60 15 30 32
8 33 51 43 1 14 17 63 2 46 27 62 38 13 33 12
5 34 3 43 54 33 27 32 7 6 63 22 36 48 9 7
29 21 17 55 33 2 44 12 8 7 15 39 20 37 7 2
25 10 13 4 4 27 55 30 17
End log file
I had the DMAD set to make random numbers from 1 to 64, and
was using a smoke detector as my radiation source.
BTW Here are the links to the programs I used.
Terminal
http://sites.google.com/site/terminalbpp/
Replace Pioneer
http://www.mind-pioneer.com/
