Wrtradio 0.1 not for 4MB Flash
Postby ilinux » Thu Jan 07, 2010 12:06 pm
Hello everybody,
I've just finish to compile a new firmware with a mpd patched to last version (0.17.5) in the 8.09.1 fimware.
All my work is ready for testing by you if you want.
I change audio server to alsa because with this version mpc volume command wasn't working. In the future the mpc volume will be removed from mpc source and you can use amixer included in the repo.
The file /etc/mpc.conf should have this
audio_output {
type "alsa"
name "My ALSA Device"
device "hw:0,0" # optional
format "44100:16:2" # optional
mixer_device "default" # optional
mixer_control "PCM" # optional
mixer_index "0" # optional
I've also put in the repo some useful packages for mount usb devices and windows sharing (cifs).
I will also add support for hid ir remote (ir remote seen like a usb keyboard).
All the work is under CC licence.
Some other info about mpd
Supported decoders:
[mad] mp3 mp2
[vorbis] ogg oga
[flac] flac
Supported outputs:
shout null fifo alsa oss httpd
Supported protocols:
file:// http:// lastfm:// mms:// mmsh:// mmst:// mmsu://
Useful changelog of mpd is in the NEWS file here:
https://sourceforge.net/projects/musicp ... 2/download
Let me know if all is ok, i've test the mpd /mpc with slay radio and works ;)
@MigthyOhm and all
If you want share a creation of ready firmware with all included (mpd,mpc,sound server,ecc...)
All this is at:
http://www.sandrofabbro.com/wrtradio/
ilinux
Re: New firmware compiled & for testing!
Postby regiscruzbr » Thu Jan 07, 2010 5:31 pm
Very nice job ilinux!!!
I had try upgrade my mpd about hundred times, but I don't have the necessaries skills to build my own package. Than I concentrate my little free time on the hardware interface to my radio, I hope show it for you guys soon.
I'm very excited to test your version.
Thanks, thanks, thanks!!!
:D
regiscruzbr
Postby mightyohm » Thu Jan 07, 2010 6:53 pm
ilinux -
Wow, nice job! I know a lot of people will be excited to try out the new version of mpd.
How much free space is available on your router (WL-520gU?) with ALSA and the new mpd / dependencies installed?
Postby ilinux » Fri Jan 08, 2010 6:34 am
Hi Jeff,
This is steps I follow after flashing:
Add this repo and comment the openwrt default:
src/gz snapshots http://www.sandrofabbro.com/wrtradio/v0.1/packages
root@wrtradio:/# opkg update
root@wrtradio:/# opkg install kmod-usb-ohci kmod-alsa kmod-sound-core alsa-utils alsa-lib mpd mpc ntpclient
(maybe alsa-utils is not necessary but alsa-lib yes because mpd cannot play for libasound2.so error :D )
root@wrtradio:/# df -h / && df -h /jffs/
Filesystem Size Used Available Use% Mounted on
mini_fo:/jffs 1.4M 1.4M 0 100% /
/dev/mtdblock/4 5.9M 4.0M 1.9M 68% /jffs
There also some other packages like usb storage if someone need and cifs module utils for mount samba / windows filesharing
I've tested mp3 streaming and lastfm and work. I've some problem with mms like streaming (maybe il libmms5 buggy I don't know :evil: )
ilinux
Postby eli2k » Mon Jan 11, 2010 7:44 pm
Is this the proper way to mount windows shares?
mount -t cifs //10.0.0.100/some_share /mnt/cifs -o username=shareuser,password=sharepassword,domain=nixcraft
What do you do if there is no username/password or domain?
eli2k
Postby andn » Sun Jan 17, 2010 5:23 am
Hi Jeff, hello everybody!
This is a great project, I'm really amazed. Thank you.
Trying to set up my 500 gP with the new build by ilinux, have some difficulties to master. Some of them are quite strange to me for which I couldn't find any help on the net. I'll try to describe it. Hope you'll be patient (my first forum post in english).
1. Opkg errors due to architecture compatibility. My opkg.conf:
[list=]#src/gz snapshots http://downloads.openwrt.org/snapshots/ ... 4/packages
#src/gz snapshots http://www.sandrofabbro.com/wrtradio/v0.1/packages/
#src/gz http://downloads.openwrt.org/kamikaze/8 ... /packages/
src/gz snapshots http://downloads.openwrt.org/kamikaze/8 ... /packages/
arch brcm4704 1
dest root /
dest ram /tmp
lists_dir ext /var/opkg-lists
option overlay_root /jffs
[/list]
Hashed repos are earlier trials to get them right. Cannot install anything by direct links too.
2. Most important to me: no go with streaming at 128 kbit. Connection is right, but no output. The same thing with files stored on the memory. Is it possible that my soundcard can't handle it? Should the connection not break if the decoder isn't able to manage the stream?
3. Volume control isn't working. Actually it works but in a strange manner: mpc volume n/a, alsamixer only very limited (full or at 10% almost full volume). The config is taken from mpd site:
    audio_output {
    type "alsa"
    name "My alsa Device"
    device "mpdvol" # optional
    ## format "44100:16:2" # optional
    ## mixer_device "/dev/mixer" # optional
    ## mixer_control "PCM" # optional
    mixer_type "alsa"
    mixer_device "mpdvol"
    mixer_control "MPD"
http://mpd.wikia.com/wiki/Configuration ... me_control
4. Obviously I'm doing something wrong trying to compile the svn. The router just blinks with its power led, no telnet. At last can reflash it with no problems. With no serial cable can't check the boot listing. Frustrating.
Even dough it's a really, really nice project, which I want to push forward with building an simple but good gainclone amp and speakers, remote.
Thanks for any help.
andn
Postby mightyohm » Sun Jan 17, 2010 11:38 am
Are you using a 500gP or a 500gP v2? Easiest way to tell is if the wifi card is a separate plugin module in the router. The code that ilinux posted should work on the v2, but probably not the original since it uses a different wifi chipset. This might explain the opkg problems.
Definitely get a serial cable if you plan to spend any time flashing / debugging different firmware builds. You are working blind without one.
Postby andn » Sun Jan 17, 2010 2:32 pm
Thank you for reply. The thing is I have the v1, wi-fi works great on ilinuxes build. Still can't find a workaround for that mess with repos, but I'm desperatly working on it.
By the way: ever heard of slimserver or firefly media server?
andn
Postby mightyohm » Sun Jan 17, 2010 2:47 pm
What error message are you getting from opkg?
Have you tried asking over on the OpenWrt forums? Maybe a search over there will turn up the answer.
I have heard of both firefly and slimserver, but I have no experience with either. My primary goal for the wifi radio was to listen to shoutcast streams. Once I got that working I put the radio into regular use and haven't needed to change anything since. :) I know a lot of people are interested in getting those apps working on the 520gu, so if you do make any progress, please post back here.
Postby ilinux » Tue Jan 19, 2010 12:03 am
This is my /etc/opkg.conf:
dest root /
dest ram /tmp
For /etc/mpd.conf:
music_directory "~/music"
playlist_directory "~/.mpd/playlists"
db_file "~/.mpd/database"
audio_output {
type "alsa"
This is the alsamixer with c-media soundcard
ilinux
Next
cron
