I was wondering if anyone has had any success using a usb hub with the SYBA audio device? I purchased a hub and tried the setup with just the SYBA plugged into it, and I could barely hear anything from my speakers and what I could hear was distorted. Since the hub can be powered, I gave it some juice and still got the same result. When the SYBA is plugged directly into the ASUS, it works like a charm. I am planning on using an Arduino with this and figured the USB port would be the easiest way to go as it would provide both power and communications. So, does anyone have any set up with a usb hub and the SYBA?
