Stuck on part 5
Stuck on part 5
Postby denniston » Fri Jan 29, 2010 10:58 pm
Hi everyone,
I'm new to openwrt, but quite familiar with hotrodding routers. I picked up a WL-520GU the other day,then had to wait for weeks for my usb sound card to arrive from HongKond. Wish I would have paid a little more attention when I was bidding :)
Anyway I have installed the openwrt-brcm-2.4-squashfs.trx and got through the first 4 steps, but when I try to "opkg install kmod-usb-audio kmod-usb-ohci" I get this error:
Collected errors:
* pkg_hash_fetch_best_installation_candidate: Packages for kmod-usb-audio found, but incompatible with the architectures configured
* opkg_install_cmd: Cannot install package kmod-usb-audio.
* pkg_hash_fetch_best_installation_candidate: Packages for kmod-usb-ohci found, but incompatible with the architectures configured
* opkg_install_cmd: Cannot install package kmod-usb-ohci.
Any ideas? Thanks in advance for your help.
denniston
Re: Stuck on part 5
Postby denniston » Sat Jan 30, 2010 11:02 am
I did a reboot on the router, and now I get this error when I try to "opkg install kmod-usb-audio kmod-usb-ohci"
root@OpenWrt:/# opkg install kmod-usb-audio kmod-usb-ohci
Collected errors:
denniston
Re: Stuck on part 5
Postby mightyohm » Mon Feb 01, 2010 9:14 pm
Can you post your /etc/opkg.conf?
Re: Stuck on part 5
Postby denniston » Mon Feb 01, 2010 9:24 pm
src/gz snapshots http://mightyohm.com/files/kamikaze-2.4/packages/mipsel
dest root /
dest ram /tmp
lists_dir ext /var/opkg-lists
option overlay_root /jffs
- /etc/opkg.conf 1/5 20%
denniston
Re: Stuck on part 5
Postby mightyohm » Mon Feb 01, 2010 9:31 pm
Ok, assuming you used the .trx file in the tutorial, and Asus hasn't changed architectures on us, this should work...
Try typing "opkg update" followed by "opkg install kmod-usb-ohci" again, and see what happens.
You might want to post the output of dmesg as well. What audio device are you using?
Re: Stuck on part 5
Postby denniston » Mon Feb 01, 2010 9:40 pm
root@OpenWrt:/# opkg update
Downloading http://mightyohm.com/files/kamikaze-2.4 ... ackages.gz.
Inflating http://mightyohm.com/files/kamikaze-2.4 ... ackages.gz.
Updated list of available packages in /var/opkg-lists/snapshots.
root@OpenWrt:/# opkg install kmod-usb-ohci
Collected errors:
root@OpenWrt:/# dmesg
CPU revision is: 00029029
Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes.
Primary data cache 16kB, 2-way, linesize 16 bytes.
Linux version 2.4.37.5 (sandro@openwrt-sdk) (gcc version 3.4.6 (OpenWrt-2.0)) #3 Thu Jan 7 17:30:25 CET 2010
Setting the PFC to its default value
Determined physical RAM map:
memory: 01000000 @ 00000000 (usable)
On node 0 totalpages: 4096
zone(0): 4096 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: root=/dev/mtdblock2 rootfstype=squashfs,jffs2 init=/etc/preinit noinitrd console=ttyS0,115200
CPU: BCM5354 rev 3 at 240 MHz
Using 120.000 MHz high precision timer.
Calibrating delay loop... 237.56 BogoMIPS
Memory: 14248k/16384k available (1437k kernel code, 2136k reserved, 100k data, 84k init, 0k highmem)
Dentry cache hash table entries: 2048 (order: 2, 16384 bytes)
Inode cache hash table entries: 1024 (order: 1, 8192 bytes)
Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 4096 (order: 2, 16384 bytes)
Checking for 'wait' instruction... unavailable.
POSIX conformance testing by UNIFIX
PCI: no core
PCI: Fixing up bus 0
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
Registering mini_fo version $Id$
devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
JFFS2 version 2.1. (C) 2001 Red Hat, Inc., designed by Axis Communications AB.
squashfs: version 3.0 (2006/03/15) Phillip Lougher
pty: 256 Unix98 ptys configured
Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled
ttyS00 at 0xb8000300 (irq = 3) is a 16550A
ttyS01 at 0xb8000400 (irq = 3) is a 16550A
b44.c:v0.93 (Mar, 2004)
PCI: Setting latency timer of device 00:01.0 to 64
eth0: Broadcom 47xx 10/100BaseT Ethernet 90:e6:ba:8b:4c:90
Physically mapped flash: Found an alias at 0x400000 for the chip at 0x0
Physically mapped flash: Found an alias at 0x800000 for the chip at 0x0
Physically mapped flash: Found an alias at 0xc00000 for the chip at 0x0
Physically mapped flash: Found an alias at 0x1000000 for the chip at 0x0
Physically mapped flash: Found an alias at 0x1400000 for the chip at 0x0
Physically mapped flash: Found an alias at 0x1800000 for the chip at 0x0
Physically mapped flash: Found an alias at 0x1c00000 for the chip at 0x0
Amd/Fujitsu Extended Query Table v1.1 at 0x0040
number of CFI chips: 1
cfi_cmdset_0002: Disabling fast programming due to code brokenness.
Flash device: 0x400000 at 0x1c000000
bootloader size: 131072
Physically mapped flash: Filesystem type: squashfs, size=0x15c5a6
Creating 5 MTD partitions on "Physically mapped flash":
0x00000000-0x00020000 : "cfe"
0x00020000-0x003f0000 : "linux"
0x0009b400-0x00200000 : "rootfs"
mtd: partition "rootfs" doesn't start on an erase block boundary -- force read-only
0x003f0000-0x00400000 : "nvram"
0x00200000-0x003f0000 : "rootfs_data"
Initializing Cryptographic API
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 1024 bind 2048)
Linux IP multicast router 0.06 plus PIM-SM
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
NET4: Ethernet Bridge 008 for NET4.0
802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
All bugs added by David S. Miller <davem@redhat.com>
VFS: Mounted root (squashfs filesystem) readonly.
Mounted devfs on /dev
Freeing unused kernel memory: 84k freed
diag: Detected 'ASUS WL-520gU'
roboswitch: Probing device eth0: found a 5325! It's a 5350.
mini_fo: using base directory: /
mini_fo: using storage directory: /jffs
jffs2.bbc: SIZE compression mode activated.
eth0.0: add 01:00:5e:00:00:01 mcast address to master interface
eth0.1: add 01:00:5e:00:00:01 mcast address to master interface
eth0.0: dev_set_promiscuity(master, 1)
device eth0 entered promiscuous mode
device eth0.0 entered promiscuous mode
br-lan: port 1(eth0.0) entering learning state
br-lan: port 1(eth0.0) entering forwarding state
br-lan: topology change detected, propagating
PCI: Setting latency timer of device 00:05.0 to 64
PCI/DMA
wl0: wlc_attach: chiprev 3 coreunit 0 corerev 13 cccap 0x104007ea maccap 0x30482205 band 2.4G, phy_type 5 phy_rev 0 ana_rev 6
wl0: Broadcom BCM4318 802.11 Wireless Controller 4.150.10.5
ip_conntrack version 2.1 (5953 buckets, 5953 max) - 336 bytes per conntrack
device wl0 entered promiscuous mode
wl0: attempt to add interface with same source address.
br-lan: port 2(wl0) entering learning state
br-lan: port 2(wl0) entering forwarding state
root@OpenWrt:/#
denniston
Re: Stuck on part 5
Postby denniston » Mon Feb 01, 2010 9:51 pm
I never really thought about it, but my audio adapter is a Hong Kong special that I got off ebay. I thought it looked alot like the SYBA that you suggested so I went for it. Do you think that might be the problem?
denniston
Re: Stuck on part 5
Postby mightyohm » Mon Feb 01, 2010 10:19 pm
Did you compile your own trx file? I suspect you did, based on this line:
vs my router
Linux version 2.4.35.4 (jkeyzer@wavelen) (gcc version 3.4.6 (OpenWrt-2.0)) #3 Mon Dec 1 17:35:57 PST 2008
Something about your setup is making opkg unhappy. Possibly opkg changed and it doesn't like the old package files on my site? I admit I am surprised that there is incompatibility within the same kernel version, but then again I compiled my trx file and packages over a year ago. I suspect that if you match the package repository to the trx (my trx and my repository or your trx and your own repository) then you might have an easier time getting things working.
Alternatively use the trx file that I provide and you should be able to follow the tutorial verbatim.
Re: Stuck on part 5
Postby denniston » Tue Feb 02, 2010 7:12 am
I'm sure I didn't compile my own kernel, but I may have accidently downloaded and installed the trx file from the openwrt site. I'll reflash the router with your distro and see where we get.
denniston
Re: Stuck on part 5
Postby denniston » Tue Feb 02, 2010 5:54 pm
I've reflashed the router, and double checked all the steps and now I get an error before the error I was getting before.
Here's my log:
root@OpenWrt:/# ping 98.129.212.1
PING 98.129.212.1 (98.129.212.1): 56 data bytes
64 bytes from 98.129.212.1: seq=0 ttl=52 time=68.296 ms
64 bytes from 98.129.212.1: seq=1 ttl=52 time=50.948 ms
64 bytes from 98.129.212.1: seq=2 ttl=52 time=58.016 ms
64 bytes from 98.129.212.1: seq=3 ttl=52 time=48.203 ms
64 bytes from 98.129.212.1: seq=4 ttl=52 time=50.844 ms
64 bytes from 98.129.212.1: seq=5 ttl=52 time=50.090 ms
--- 98.129.212.1 ping statistics ---
6 packets transmitted, 6 packets received, 0% packet loss
round-trip min/avg/max = 48.203/54.399/68.296 ms
Connecting to mightyohm.com (98.129.212.1:80)
wget: cannot connect to remote host (98.129.212.1): Connection timed out
Signiture check for snapshots skipped because GPG support was not enabled in this build
Collected errors:
* opkg_download: ERROR: Command failed with return value 1: `wget --passive-ftp -P /tmp/opkg-Bih2rJ http://mightyohm.com/files/kamikaze-2.4 ... ckages.gz'
root@OpenWrt:/#
denniston
Next
Users browsing this forum: Yahoo [Bot] and 2 guests
