for those of you having trouble as WPA2 client
Posted: Tue Feb 16, 2010 2:22 pm
by akula169
{EDIT} I previously thought this was the fix to my problem, I was wrong... please read the next post {/EDIT}
I futzed with my setup for hours before I figured out that single quotes around the key are pretty much required, at least in my case...
Before I noticed this, it was quite bewildering, as iwconfig showed the AP's MAC address as associated, but wl0 could never get a DHCP offer.
Here's what my config looks like now:
config wifi-device wl0
option type broadcom
option channel 1
# option disabled 1
option device wl0
option network wan
option mode sta
option ssid MySSID
option encryption psk2
option key 'MyWPA2Key'
Re: for those of you having trouble as WPA2 client
Posted: Tue Feb 16, 2010 3:32 pm
by akula169
OK, so scratch that. My wireless was working for a minute... until I rebooted.
Now its broken again. Not sure what changed.
Posted: Tue Feb 16, 2010 4:14 pm
by akula169
OK, so I dropped my AP down to WPA Personal from WPA2 Personal
Now it works with "option encryption psk"
Now... I'm wondering why WPA2 doesn't want to work with my router... anyone else having success with WPA2 client configs? I'd really rather not have to downgrade to WPA just to support my asus client connection.
Posted: Wed Feb 17, 2010 1:13 am
by jeroen94704
It is a known issue with OpenWrt that WPA2 does not work in client mode. I have no idea what the status of this issue is, and if/when it will be resolved, but for now, if you want to use an OpenWrt box as a wireless client, you are forced to drop to WPA.
Note that with a key of the proper length (AT LEAST more than 20-25 characters), this is no less secure.
Posted: Wed Feb 17, 2010 1:19 am
by akula169
Thanks for the clarification about the known issue.
I'm by no means a linux noob, but my experience with OpenWRT is now all of about 16 hours old...
Posted: Wed Feb 17, 2010 1:24 am
by jeroen94704
OpenWRT rules, but the focus is definitely on a specific application (routers). Many things outside that narrow scope tend to require a bit more fiddling to get working, and that includes stuff like getting it to work as a client, USB sound etc.
Posted: Wed Feb 17, 2010 1:31 am
by akula169
jeroen94704 wrote:OpenWRT rules
Indeed. A robust embedded development platform with ethernet hub, wireless, serial console and USB for less than $35? I'll be buying a handful of these 502gu's! I'm already dreaming up new applications for the hardware...
Posted: Fri Nov 12, 2010 6:34 pm
Does anyone know if any of the more recent OpenWrt releases support wpa2-aes?
