Page 3 of 3
Re: Anybody get the 520gU wireless (B43) to work with 2.6 ke
Posted: Wed Nov 16, 2011 8:39 am
by lostmyshape
IggyCeltic, thanks for the help, but it looks to me like you're actually using the 2.4 kernel. Somebody correct me if I'm wrong but the "broadcom" driver (in the wireless config: "option 'type' 'broadcom'") is from the brcm-2.4. From what I understand from wiki.openwrt.org, the 2.6 kernel uses the b43 driver built into mac80211.
The good news is that I have pulseaudio working pretty well. There are some stutters and disconnects, but quality is better than I ever got with MPD on the WL-520gu. Of course this is wired to my main router. I'd love to get wireless working on trunk with the 2.6 kernel.
Maybe it's security? My router logs seem to say that the 520gu is connecting, and ifconfig shows me an IP address, but I can't ping anything out from the 520gu or ping the box at that address. So weird.
Posted: Thu Dec 01, 2011 10:10 pm
by dext3r
I have been able to get wireless working on backfire RC5 r27608 without any fixes or anything, just edit the network/wireless config files.
the odd thing though, is i have one 520gu running solid for a couple weeks now, but another is getting random wifi radio fuckups, (thats a technical term) causing the wireless to crash "hard balls" (another technical term)
i tried using backfire RC6 and bleeding edge trunk (attitude adjustment) and I couldn't get wireless to work at all. used the name network/wireless config files as the working RC5 install. im getting an error related to wpa_supplicant authentication, not sure why. (sorry, dont know the exact error off the top of my head and cant get to the router right now)
im gonna try RC5 again tomorrow ,we'll see if it works.
Posted: Thu Dec 01, 2011 10:11 pm
by dext3r
lostmyshape wrote:IggyCeltic, thanks for the help, but it looks to me like you're actually using the 2.4 kernel. Somebody correct me if I'm wrong but the "broadcom" driver (in the wireless config: "option 'type' 'broadcom'") is from the brcm-2.4. From what I understand from wiki.openwrt.org, the 2.6 kernel uses the b43 driver built into mac80211.
do you have the firewall running?
Posted: Sun Dec 04, 2011 11:32 pm
by dext3r
OK got it connected with Attitude Adjustment, bleeding edge.
BusyBox v1.19.3 (2011-12-01 00:51:01 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
  _______                     ________        __
 |       |.-----.-----.-----.|  |  |  |.----.|  |_
 |   -   ||  _  |  -__|     ||  |  |  ||   _||   _|
 |_______||   __|_____|__|__||________||__|  |____|
          |__| W I R E L E S S   F R E E D O M
 ATTITUDE ADJUSTMENT (bleeding edge, r29366) ----------
  * 1/4 oz Vodka      Pour all ingredients into mixing
  * 1/4 oz Gin        tin with ice, strain into glass.
  * 1/4 oz Amaretto
  * 1/4 oz Triple sec
  * 1/4 oz Peach schnapps
  * 1/4 oz Sour mix
  * 1 splash Cranberry juice
root@OpenWrt:/# uname -a
Linux OpenWrt 3.0.9 #14 Sun Dec 4 23:15:21 CST 2011 mips GNU/Linux
root@OpenWrt:/# iwconfig
lo        no wireless extensions.
eth0      no wireless extensions.
eth0.0    no wireless extensions.
eth0.1    no wireless extensions.
br-lan    no wireless extensions.
wlan0     IEEE 802.11bg  ESSID:"James Quall"
          Mode:Managed  Frequency:2.437 GHz  Access Point: 00:1D:73:B4:83:F0
          Bit Rate=24 Mb/s   Tx-Power=20 dBm
          RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:off
          Link Quality=70/70  Signal level=-8 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:7   Missed beacon:0
root@OpenWrt:/# ifconfig
br-lan    Link encap:Ethernet  HWaddr 20:CF:30:87:F1:0A
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:170 errors:0 dropped:75 overruns:0 frame:0
          TX packets:489 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:41566 (40.5 KiB)  TX bytes:196993 (192.3 KiB)
eth0      Link encap:Ethernet  HWaddr 20:CF:30:87:F1:0A
          RX packets:569 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1710 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:154434 (150.8 KiB)  TX bytes:694796 (678.5 KiB)
          Interrupt:4
eth0.0    Link encap:Ethernet  HWaddr 20:CF:30:87:F1:0A
          UP BROADCAST RUNNING PROMISC MULTICAST  MTU:1500  Metric:1
          RX packets:562 errors:0 dropped:0 overruns:0 frame:0
          TX packets:703 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:141282 (137.9 KiB)  TX bytes:271810 (265.4 KiB)
eth0.1    Link encap:Ethernet  HWaddr 20:CF:30:87:F1:0A
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1002 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:403806 (394.3 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:21672 errors:0 dropped:0 overruns:0 frame:0
          TX packets:21672 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1476123 (1.4 MiB)  TX bytes:1476123 (1.4 MiB)
wlan0     Link encap:Ethernet  HWaddr 20:CF:30:87:F1:0A
          inet addr:10.10.1.139  Bcast:10.10.1.255  Mask:255.255.255.0
          RX packets:750 errors:0 dropped:0 overruns:0 frame:0
          TX packets:345 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:32
          RX bytes:108953 (106.3 KiB)  TX bytes:39431 (38.5 KiB)
root@OpenWrt:/#
I'm using the b43 firmware version 410, which is what ive got running on my working RC5 setup.
You have to manually select this version from the configuration menu ("make menuconfig")
I have no idea if the newer versions help/hurt stability.
[  394.948000] b43-phy0: Loading firmware version 410.2160 (2007-05-26 15:32:10)
There seems to be some kind of bug with the generation of configuration files. OpenWRT reads the junk from /etc/config/wireless and builds a config file for wpa_supplicant on the fly. I manually created a wpa_supplicant config file and started it up. Then to get an IP from DHCP, ran 'udhcpc -i wlan0'.
It worked, but its different than backfire RC5, where br-lan is the interface with the IP address, but it seems to work fine.
Anybody have a good way to stress test the stability of this? Maybe looped HTTP downloads or something?
Posted: Fri Mar 09, 2012 4:59 pm
by djmasterg
dext3r
Any progress with 2.6 kernel? I have a wl 520gu, and want to try 2.6 kernel. Im not sure where to start, or what built to install. The only reason I want to try 2.6 is that I need aac playback on my asus.
Posted: Wed Mar 14, 2012 10:46 am
I would head over to openwrt.org and grab the latest release or maybe check out the trunk repository. This is definitely something you will need to play around with, I don't think there is a quick/easy "out of the box" setup that is going to work for you, but maybe things have changed in the past year or so...
Posted: Thu Mar 15, 2012 9:01 am
by gerben
from http://wiki.openwrt.org/toh/asus/wl520gu
Warning! Kernel support for the radio is broken when using the 2.6 kernel (b43 driver) via the brcm47xx target in the original Backfire (10.03) release! OpenWrt doesn't enable the radio out of the box. If you enable it, processes get killed and the box becomes unusable. The issue is discussed in https://dev.openwrt.org/ticket/6907
But I don't think you need the 2.6 kernel. Newer versions of MPD can run just fine on 2.4, if I'm correct.
PS. I think it is time for you to just get your hand dirty. Just flash the router with the newers OpenWrt with 2.4 kernel and see if you get AAC working. There isn't much you can do wrong (especially with an Asus). And if you find out you'll need another version, just reflash it. ;)
