My wireless configuration (WPA + PSK) looks like this:
- Code: Select all
config wifi-device wl0
option type broadcom
option channel 7
option device wl0
option network lan
option mode sta
option ssid <my ssid>
option encryption psk
option key <my key>
According to http://dev.luci.freifunk-halle.net/docsrv/section.wireless.wifi-iface.xml#variable.wds For WPA and PSK I would need to use "psk" as encryption parameter. I could not find any information on what format the encryption key should be placed in the wireless config file. I assumed plain text. But it does not look to me I'm getting to that stage yet.
my network configuration is default:
- Code: Select all
#### VLAN configuration
config switch eth0
option vlan0 "1 2 3 4 5*"
option vlan1 "0 5"
#### Loopback configuration
config interface loopback
option ifname "lo"
option proto static
option ipaddr 127.0.0.1
option netmask 255.0.0.0
option type bridge
option ifname "eth0.0"
# option proto static
option proto dhcp
# option ipaddr 192.168.1.1
# option netmask 255.255.255.0
When I start my network I get the following:
- Code: Select all
root@OpenWrt:/#
root@OpenWrt:/#
root@OpenWrt:/# /etc/init.d/network restart
br-lan: port 2(wl0) entering disabled state
br-lan: port 1(eth0.0) entering disabled state
device wl0 left promiscuous mode
device eth0.0 left promiscuous mode
device eth0.0 entered promiscuous mode
br-lan: port 1(eth0.0) entering learning state
br-lan: port 1(eth0.0) entering forwarding state
br-lan: topology change detected, propagating
device wl0 entered promiscuous mode
wl0: attempt to add interface with same source address.
br-lan: port 2(wl0) entering learning state
br-lan: port 2(wl0) entering forwarding state
Received SIGTERM
Entering released state
udhcpc (v1.11.2) started
Sending discover...
root@OpenWrt:/# Sending discover...
Sending discover...
From what I can see the wireless LED never blinks (not sure if it does blink during setup). What am I doing wrong? Any hint on what I could check?
I reviewed
- Code: Select all
/tmp/log
