wl-520gu usart - turn off echo
hub.martin
Post by hub.martin »
Hello. I'm playing with serial line on the router. When I send text from the router I can read it on the computer. When I do it in the other way, from computer to router, the router sends me back all text that I sent to it. Do I forget something to turn off? I don't want echo from router because this will make parsing data on AVR more complicated. Any idea what's wrong?
The bash is disabled in inittab
root@OpenWrt:~# cat /etc/inittab
::sysinit:/etc/init.d/rcS S boot
::shutdown:/etc/init.d/rcS K stop
#tts/0::askfirst:/bin/ash --login
#ttyS0::askfirst:/bin/ash --login
tty1::askfirst:/bin/ash --login
Re: wl-520gu usart - turn off echo
Try stty -echo < /dev/tts/0
hub.martin
Thanks, I'll try it at the weekend.
did it work?
hub.martin
Yes, absolutely! Thank you.
