Help Hack WL 520GU
Help Hack WL 520GU
Postby zordlyon » Fri Dec 03, 2010 12:58 pm
Hi people, i buy one WL520GU for a arduino project....
With the metod of the restoration tool i has installed the DD-WRT in my router...
but my question is if with the DD-WRT i can comunicate with the arduino?
And my other question, i has made a serial cable to comunicate with the serial of the ASUS but i'm not sure it will work...and after i burn my serial port i need the sure it will work and what i did is in this photos:
the links are left to right...
Asus - GND - TX - RX - 3v3
Cable - GND - RX - TX - (unplugged)
The conversor is one USB-RS232 conversor...
Is anything wrong?
My question is, i can connect to my computer this way??
Thanks everyone, and sorry for my english (i'm portuguese)..
zordlyon
Re: Help Hack WL 520GU
Postby mightyohm » Fri Dec 03, 2010 1:03 pm
No, that probably won't work. You need a USB to serial converter that outputs 3.3V TTL levels, not RS-232 levels. The DB-9 connector is a giveaway that you are using the wrong kind.
I like the FTDI 3.3V cable here:
http://www.adafruit.com/index.php?main_ ... ucts_id=70
I've heard you can also use some Nokia cell phone cables if you take them apart...
Postby zordlyon » Fri Dec 03, 2010 1:16 pm
Hum thanks for the fast reply...
In portugal i dont know where i find these cables...i need search...
Thanks..
zordlyon
Postby mightyohm » Fri Dec 03, 2010 1:21 pm
You probably can find nokia data cables though - more info here:
http://hackaday.com/2010/02/25/nokia-us ... -disguise/
Postby zordlyon » Fri Dec 03, 2010 1:58 pm
Hum, every cables Nokia with connector ca - XX have converter 232r -3v3 ??
i have one of these:
is the cable Nokia Ca-53...and what you link before is Ca-42...
Thanks..
zordlyon
Postby mightyohm » Fri Dec 03, 2010 2:19 pm
Apparently you need to get the CA-42 and the CA-53 won't work. :(
http://discussions.europe.nokia.com/t5/ ... m-p/152339
Postby zordlyon » Fri Dec 03, 2010 2:28 pm
I just have buyed a cable of adafruit, i have finded one.. :D
The DD-WRT is gona work with arduino?
Or what is the firmware you recomend install? If it the Open-WRT you recomend install with the mode of "restoration tool" or via serial??
You can post the link of the recomended firmware if the DD-WRT is not the best solution please?
My project consist in send information via wireless to an arduino and the arduino control 2 motors, and 1 webcam link to USB of the router..and send images to a computer via broadcast...
Thanks very much for the help...
I gona publish your help on my project...
zordlyon
Postby dext3r » Fri Dec 03, 2010 3:51 pm
zordlyon wrote:I just have buyed a cable of adafruit, i have finded one.. :D
I would suggest using OpenWRT as in the WiFi Radio guide. You can load DD-WRT on the router and it will work, but it seems much more specific for actual network/routing and a bit harder to customize. There are at least a couple docs/blogs on making custom OpenWRT packages, wheras I could not find very good information on doing the same for DD-WRT. Too much hassle with DD-WRT, I would stick with OpenWRT.
I would also suggest loading it via TFTP or restoration tool.
dext3r
Postby zordlyon » Fri Dec 03, 2010 3:59 pm
Hum thanks, and you can link me the OpenWRT i need download for my router via Restoration tool?
Just because i have founded 1001 links of compiled's openwrt and i never know who is the best..or the right one...
And for the restoration tool its more easy to flash...
Thanks..
zordlyon
Postby mightyohm » Fri Dec 03, 2010 4:22 pm
I don't know anything about the restoration tool. Is this something that runs on your PC, or via a web interface on the router??
I always use tftp, it is harder to learn but I know it works with the openwrt firmware images...
Next
cron
