I successfully installed OpenWrt on my router as per instructions on the blog. I installed different packages using opkg and decided to reinstall OpenWrt.
However I'm having trouble transferring the .trx file on to the router. I'm using a macbook pro with airport disabled since my home network is also in the 192.168.1.x range. I'm also using the USB-serial FTDI cable withZTerm. The lan cable is connected to the LAN1 and macbook pro. I get following output on the Terminal:
tftp> trace
Packet tracing off.
tftp> trace
Packet tracing on.
tftp> timeout 1
tftp> mode binary
tftp> connect 192.168.1.1
tftp> put openwrt-brcm-2.4-squashfs.trx
sent WRQ <file=openwrt-brcm-2.4-squashfs.trx, mode=octet>
Transfer timed out.
Reading :: TFTP Server.
Failed.: Timeout occured
BUF == NULL!!
BUF == NULL!!
BUF == NULL!!
break!! by max retry!!
