Page 4 of 5
Re: alternatives to the WL-520gU
Posted: Sat Mar 10, 2012 5:51 am
by gerben
Posted: Sat Mar 10, 2012 10:35 am
by djmasterg
Do you know if the mpd supports aac+ in that version (kernel 2.4)?
Posted: Sat Mar 10, 2012 1:04 pm
by gerben
See the package list: http://downloads.openwrt.org/backfire/1 ... /packages/
The mpd version in the latest openwrt is mpd_0.15.8. You would need to check if AAC is enabled in that version.
Posted: Sat Mar 10, 2012 3:21 pm
by djmasterg
No luck, installed 2.4 kernel, tried latest mpd / mpc and no aac+ support. I will look for solutions and post my experience here. thanks.
Posted: Sun Mar 11, 2012 12:02 am
by djmasterg
All right, a little bit of update:
On my asus wl 500gp v2 I have installed 10.03.1 stable release of backfire. Got it working with no problem - standard configuration for network and wireless. So I downloaded packages for audio daemnon mpd and player mpc. Everytning went fine again. Then I started to edit mpd.conf
audio_output {
        type            "oss"
        name            "My OSS Device"
        device          "/dev/sound/dsp"
        format          "44100:16:2"
#       mixer_type      "hardware"
#       mixer_device    "/dev/mixer"
#       mixer_control   "PCM"
and got a message after starting mpd:
root@OpenWrt:/# mpd
output: line 213: No such audio output plugin: oss
Worth mentioning that mpd here is mpd_0.16.1-1_brcm-2.4.ipk so hopefully it will manage aac, and I get the packages and distro from http://downloads.openwrt.org/backfire/1 ... /packages/
Posted: Wed Mar 14, 2012 10:41 am
djmasterg wrote:Thanks Jeff,
Have you got by any chance an Openwrt compiled for wl500gp v2? If not, could you guide me on which compilation to use ?
I used the same exact firmware that I use on the WL-520gu. It's based on kamikaze and an older version of mpd without AAC etc. support.
Posted: Mon Apr 16, 2012 5:17 am
by jumperonline
question has anyone hacked a bt homehub version 1 or 1.5 by any chance seeing as I have one of those hunks of plastic lying around somewhere
Posted: Mon Aug 06, 2012 4:48 am
by ilinux
The TP-LINK TL-MR3020 router in europe the price is under 40€ i think in usa should be similar and works with internet streams like video here
http://www.youtube.com/watch?v=dTgVhHvbyw8
Posted: Thu Aug 09, 2012 3:29 am
by danitool
jumperonline wrote:question has anyone hacked a bt homehub version 1 or 1.5 by any chance seeing as I have one of those hunks of plastic lying around somewhere
Those routers are very similar to the Livebox 1, I was able to run mpd in my Livebox without any problem. So to make a wifi radio with homehubs is more than possible since they have 32 MiB RAM (the livebox only 16 MiB).
Posted: Fri Aug 10, 2012 3:53 am
by gerben
I'd like to add the Raspberry Pi to the list. http://www.farnell.com/raspberrypi/
I recently bought a Raspberry Pi. The first think I did was install MPD onto it, and it was playing music within minutes. I did cost 32 British pounds = 40.65 Euros, so about the same as and entry level router.
Plus sides:
+ It already has audio out, so no need for an usb-sound adapter.
+ 700 MHz CPU
+ 256 MB SDRAM
+ 2 USB ports
+ Can play 1080p via HDMI.
+ Composite out for old tv's
+ SD card slot, so easily extendable memory. (No more 4MB limit, but more like a 32GB limit :-) )
+ 17 GPIO connections, so you might be able to ditch the micro controller completely
+ Support for multiple OS distributions.
Downsides:
- It doesn't have wifi, so you'll need a usb wifi adapter.
- Doesn't include a power adapter (5v, 700mA, micro usb)
- No internal Flash memory, so requires a SD card, that isn't included
- Doesn't have an enclosure
PS Also check the upcoming APC from VIA (http://apc.io/). A bit more expensive, and currently only supports Android.
