MPD Install Fails
pbennison
MPD Install Fails
Post by pbennison »
Hello all,
New to the forum and trying to do the wifi radio.
First ran into problems with the Kamikaze version then did Backfire and got further, but still ran into problems at the install mpd step when I get a space issue.
Only have 876kb available on filesystem /overlay, pkg glib2 needs 1601
* opkg_install_cmd: Cannot install package mpd
I searched and found the following "viewtopic.php?f=2&t=522&p=2195&hilit=ca ... +mpd#p2195".
It says to:
No need to recompile. Either use the build Jeff has compiled for us, or use the standard openwrt build you have right know (that openwrt has compiled for you). Jeffs is more lightweight making MPD fit into the 4MB of flash memory the wl520gu has. The newer version of Openwrt you have right now, also has a newer version of MPD which is more bloated and won't fit in the 4MB flash.
But I have no idea where Jeff's build is. Can someone point me in the right direction? This seems like the easiest way to go.
Thanks...Pat
Re: MPD Install Fails
Jeff is the owner of this website.
The original post that refers to the openwrt-image:
http://mightyohm.com/blog/2008/11/build ... g-openwrt/
direct link:
http://mightyohm.com/files/kamikaze-2.4 ... uashfs.trx
pbennison
Post by pbennison »
So cool, just returned from a week away. Thanks for the quick reply. I will try it first thing today..
pbennison
Post by pbennison »
Awesome, that did the trick thanks for the help...
