Air light NOT coming on
Postby Macgos » Tue Mar 22, 2011 9:58 pm
First - thanks for providing a great site. I am all very new to this, but I am learning a lot by reading your tutorials. I am trying to make tinkernuts version of the Wifi radio - as this is a big enough learning curve for me. I realise this forum isn't specifically for his version, but as his forum is read only, and as the problems I am having are with the Asus WL-520GU, I am hoping some of you guys may be able to help me. :?
I have followed along to the youtube clip right up until the point where I enter this command : /etc/init.d/network restart
After this - nothing happens. The air light doesn't light up - which I presume would indicate is that its not connected to my wireless network.
I have tried many different versions of router, network IP address - but nothing seems to work. I am NOT even sure if I am using the correct router or network addresses. In a similar post on these forums, a suggestion was made to change to WEP encryption - which I have done. I have also run ifconfig and taken a look at the addresses there. Still no joy.
As I am a newbie with all of this, I bet it is a simple problem, so i am kinda hoping someone may be able to help.
Here are my settings - note I have blanked out my password for my wireless network:
KAMIKAZE (bleeding edge, r12857) -------------------
  * 10 oz Vodka       Shake well with ice and strain
  * 10 oz Triple sec  mixture into 10 shot glasses.
  * 10 oz lime juice  Salute!
root@OpenWrt:~# vi /etc/config/wireless
config wifi-device  wl0
        option type     broadcom
        option channel  5
        # option disabled 1
        option device   wl0
        option network  lan
        option mode     sta
        option ssid     Goston Wireless
        option encryption wep
        option key      xxxxxxxxxx
root@OpenWrt:~# vi /etc/config/network
#### VLAN configuration
config switch eth0
        option vlan0    "1 2 3 4 5*"
        option vlan1    "0 5"
#### Loopback configuration
config interface loopback
        option ifname   "lo"
        option proto    static
        option ipaddr   127.0.0.1
        option netmask  255.0.0.0
        option type     bridge
        option ifname   "eth0.0"
        option proto    static
        option ipaddr   192.168.69.10
        option netmask  255.255.255.0
        option gateway  192.168.1.254
        option dns      8.8.8.8
root@OpenWrt:~# /etc/init.d/network restart
It is these bits here:
that I wonder if I am doing wrong????
Also, here is my ifconfig when I plug into the Asus router and open putty then ssh.
root@OpenWrt:~# ifconfig
br-lan    Link encap:Ethernet  HWaddr 00:22:15:7F:9F:B8
          inet addr:192.168.1.1  Bcast:192.168.1.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:157 errors:0 dropped:0 overruns:0 frame:0
          TX packets:93 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:15423 (15.0 KiB)  TX bytes:9615 (9.3 KiB)
How do I find my unique network IP address - as tinkernut mentions to place in the option ipaddr ? What I have there now is my best guess looking at my Thompson router. When I enter 192.168.1.254 into my browser, i am taken to the Thompson TG585v7 page that opens my Thompson router - ....if this helps anyone. Is the 192.168.1.254 what I enter anywhere? Cos I have also tried this too...not working :?
Ok, so lots of info in this post. Any thoughts?
Thanks again for considering to help me here. This is a very exciting project - because it is pushing me well outside my comfort zone re computer stuff and I am learning a lot....
Mark
New Zealand
Macgos
Re: Air light NOT coming on
Postby Macgos » Wed Mar 23, 2011 2:06 am
Found another post with similar issues - and tried these settings instead - might be getting closer ?
        option channel  5
        option disabled 1
        option device   wl0
        option network  wan
        option mode     sta
config switch eth0
        option vlan1    "0 5"
        option ifname   "lo"
        option proto    static
        #option type    bridge
        option proto    static
        option ipaddr   192.168.1.1
udhcpc (v1.11.2) started
'wl0' is disabled
/sbin/uci: Parse error (too many arguments) at line 12, byte 32
'wl0' is disabled
root@OpenWrt:~# Sending discover...
Sending discover...
Sending discover...
I am getting closer, as now it says ...sending discover, sending discover....etc....but still no air light....... any thoughts what to do now?
Macgos
Postby mightyohm » Wed Mar 23, 2011 1:39 pm
You need quotes around your SSID because it has a space in it.
Also, make sure the channel number and WEP password is correct. You need to have the details of your wireless network entered correctly or it won't connect.
Sometimes it helps if you can alter your wireless network settings to make it "easier" to connect to, temporarily, for troubleshooting. That would be: a known channel number, such as channel 5, a simple SSID with no spaces like "TESTING", and no encryption.
Postby Macgos » Wed Mar 23, 2011 5:49 pm
Hey Jeff - thanks very much. Here is the update on my settings:
login as: root
root@192.168.1.1's password:
BusyBox v1.11.2 (2008-12-01 16:57:55 PST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
  _______                     ________        __
 |       |.-----.-----.-----.|  |  |  |.----.|  |_
 |   -   ||  _  |  -__|     ||  |  |  ||   _||   _|
 |_______||   __|_____|__|__||________||__|  |____|
          |__| W I R E L E S S   F R E E D O M
        option channel  1
        # option disabled 1
        option device   wl0
        option network  wan
        option mode     sta
        option ssid     "Goston Wireless"
        option key      xxxxxxxxxxx
config switch eth0
        option vlan1    "0 5"
        option ifname   "lo"
        option proto    static
        #option type    bridge
        option proto    static
Sending discover...
Sending select for 192.168.1.66...
Lease of 192.168.1.66 obtained, lease time 86400
adding router 192.168.1.254
deleting old routes
adding dns 192.168.1.254
Sending discover...
Sending discover...
Good news - it must now be connecting as the green AIR light is on. thanks. ;)
However, when I remove the Ethernet cable, then open putty (after activating my laptops wireless again....when I type in 192.168.1.1 (or even 192.168.1.66) to continue with the hack, nothing happens - putty just says...cant connect. I am supposed to enter the IP address for my network (according to tinkernuts instructions) - but as the suggested network config code - here on this forum, left this out - I'm not sure what to enter to continue.
Any thoughts? :)
Macgos
Postby mightyohm » Wed Mar 23, 2011 6:08 pm
With the ethernet cable connected, type "ifconfig wl0" and see what IP address the router is using on your wireless network.
Postby Macgos » Wed Mar 23, 2011 6:28 pm
Thanks Jeff here are the results:
root@OpenWrt:~# ifconfig wl0
wl0       Link encap:Ethernet  HWaddr 00:22:15:7F:9F:B8
          inet addr:192.168.1.66  Bcast:192.168.1.255  Mask:255.255.255.0
          RX packets:1638 errors:0 dropped:0 overruns:0 frame:30894
          TX packets:402 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:113138 (110.4 KiB)  TX bytes:21930 (21.4 KiB)
          Interrupt:2 Base address:0x5000
I get a Network error: Connection refused when I try to use either 192.168.1.66 or 192.168.1.255 in putty with ssh selected....
I do see the air light flickering when i use the 192.168.1.66 though...then Network error message...
This is the information my main Thompson router is picking up for the Asus:
Status: Active
Type: Generic Device
Connected To: WLAN (Wireless)
Allowed on WLAN: Yes
Addressing
Physical Address: 00:22:15:7f:9f:b8
IP Address Assignment: DHCP
IP Address: 192.168.1.66
Always use the same address: Yes
DHCP Lease Time: 49 days, 16:58:35
Macgos
Postby mightyohm » Wed Mar 23, 2011 6:51 pm
You need to configure /etc/config/firewall to allow ssh connections over the wireless interface. There's an example posted as a sticky in this forum.
Postby Macgos » Wed Mar 23, 2011 7:18 pm
ok - I have done that now...
        root@OpenWrt:~# vi /etc/config/firewall
config defaults
        option syn_flood        1
        option input            ACCEPT
        option output           ACCEPT
        option forward          REJECT
config zone
        option name             lan
        option input    ACCEPT
config zone
        option name             wan
        option input    ACCEPT
        option masq             1
config forwarding
        option src      lan
        option dest     wan
Still no access. Does the IP 192.168.1.66 the right one to be using with putty and ssh? I presume all the lines with # don't need to be entered?? Also, do I need to add Option dns 8.8.8.8 in the WAN or the option gateway line? I presume not - as you have not included them.... ;) Should the putty port number be the default 22 ?
Should I disable the wep security on my main Thompson router and see if that helps? I am just worried that anyone could then access my internet connection... :?
Macgos
Postby Macgos » Wed Mar 23, 2011 7:42 pm
oh oh ...just noticed that my apple TV is using the same Ip addy 192.168.1.66.... :o
How do i force a different Ip on the Asus??....this has got to be the problem eh??
Macgos
Postby Macgos » Wed Mar 23, 2011 8:05 pm
Ok tried this code
config switch eth0
        option vlan1    "0 5"
        option ifname   "lo"
        option proto    static
        #option type    bridge
        option proto    static
        option ipaddr   192.168.1.75
        option gateway  192.168.1.1
        option dns      8.8.8.8
now it seems like I can access it via wireless ssh....cool......do you see any problems here Jeff?
Specifically this bit:
        option dns      8.8.8.8
Macgos
Next
Users browsing this forum: Google [Bot] and 2 guests
cron
