Compiled backfire image too big
Posted: Sat Jul 30, 2011 8:50 am
i really like the wifi radio project and i also have an asus wl-520gU.
When i'm compiling a current backfire openwrt image (http://mightyohm.com/blog/2008/11/build ... g-openwrt/), i end up with an too big image, about 4,2 megs.
I tried to remove unneeded packages like ppp, iptables, ipv6, etc.. but i can't get it small enough. The same problem with the openwrt imagebuilder.
Can you explain, what modifications you did, to get such a small image?
I got the additional libraries for the imagebuilder from the ./scripts/feed install command, beacuse it seems that imagebuilder does not solve dependencies:
Thanks.
Best regards,
hberg
Installing package 'madplay'
Installing package 'libid3tag'
Installing package 'gettext'
Installing package 'libiconv'
Installing package 'libmad'
Installing package 'mpc'
Installing package 'libmpdclient'
Installing package 'mpd'
Installing package 'alsa-lib'
Installing package 'libaudiofile'
Installing package 'faad2'
Installing package 'glib2'
Installing package 'libiconv-full'
Installing package 'gettext-full'
Installing package 'curl'
Installing package 'flac'
Installing package 'libmms'
Installing package 'libshout'
Installing package 'speex'
Installing package 'libtheora'
Installing package 'libogg'
Installing package 'libvorbis'
Installing package 'libvorbisidec'
Best regards,
hberg
