i followed the tut carefully and when i excute the vi /etc/mpd.conf i get this instead of the options described in the tut. any help?
######################## REQUIRED PATHS ########################
music_directory "~/music"
playlist_directory "~/.mpd/playlists"
db_file "~/.mpd/mpd.db"
log_file "~/.mpd/mpd.log"
error_file "~/.mpd/mpd.error"
######################## OPTIONAL PATHS ########################
# If you wish to use mpd --kill to stop MPD, then you must
# specify a file here in which to store MPD's process ID.
#pid_file "~/.mpd/mpd.pid"
# If specified, MPD will save its current state (playlist,
# current song, playing/paused, etc.) at exit. This will be
# used to restore the session the next time it is run.
root@OpenWrt:~# mpd
unable to open db file "/root/.mpd/mpd.db": No such file or directory
current locale is "C"
setting filesystem charset to ISO-8859-1
No "audio_output" defined in config file
Attempt to detect audio output device
Attempting to detect a oss audio device
Error opening OSS device "/dev/dsp": No such file or directory
Error opening OSS device "/dev/sound/dsp": No such file or directory
Unable to detect an audio device
No audio_output specified and unable to detect a default audio output device
root@OpenWrt:~# vi /etc/mpd.conf
# An example configuration file for MPD
# See the mpd.conf man page for a more detailed description of each parameter.
- /etc/mpd.conf 1/276 0%
MPD install issues
Re: MPD install issues
is it because of the sound card i have used? If it helps here is a link to it
http://www.amazon.co.uk/gp/product/B003UR9B8M
I also notice when i reboot i dont get all the messages for the usb that are shown in the tut. here is a list of what i get bellow
Please press Enter to activate this console. jffs2.bbc: SIZE compression mode activated.
BFL_ENETADM not set in boardflags. Use force=1 to ignore.
usb.c: registered new driver usbdevfs
usb.c: registered new driver hub
PCI/DMA
wl0: wlc_attach: chiprev 3 coreunit 0 corerev 13 cccap 0x104007ea maccap 0x30482205 band 2.4G, phy_type 5 phy_rev 0 ana_rev 6
wl0: Broadcom BCM4318 802.11 Wireless Controller 4.150.10.5
ip_conntrack version 2.1 (5953 buckets, 5953 max) - 344 bytes per conntrack
SB USB20H init
SB COREREV: 2
SB USB20H resetting
USB20H fcr: 0x64
USB20H shim cr: 0x8f7
hub.c: USB hub found
hub.c: 2 ports detected
PCI/DMA
SB USB20H init
SB COREREV: 2
SB USB20H resetting
USB20H fcr: 0x64
Your usb-audio adapter is not supported. You will save yourself a lot of time and frustration by using the SYBA CM-UAUD or another adapter listed as working in this thread:
viewtopic.php?p=1007#p1007
Thanks for the reply Jeff.
I thought that would be the case.
I can not find the usb audio adapter described in the tut anywhere in england. How ever i have found one that uses the same chipset and apparently will work as 1.1 usb as well as 2.0.
http://www.amazon.co.uk/gp/product/B003ZM0XIY
hopefully this one should work.
PS thank you for writing this tutorial. I am a product designer and I think it is really important for companies to design their products to be able to be adapted with open source softwares and firmware. Not just so that the product is more user friendly but so that it is more versatile and can be made into something new instead of thrown into landfill, and it's people like you that enable people like me with very little electronic knowledge to do this. So thank you so much
will
will
