TL-MR3020: radio stream stops, static noise instead
PhilZYX
Post by PhilZYX » Wed Apr 13, 2016 12:45 am
Hi there,
I have set up a little wifi radio with a TP Link TL-MR3020, running MPD on OpenWRT Barrier Breaker. Everything works fine except that every now and then the stream turns into static / white noise at full volume. When i stop and restart the stream it works fine again.
Has anyone had the same problem? Maybe a internet connection issue? Or too little RAM?
Cheers,
Philipp
PhilZYX
Re: TL-MR3020: radio stream stops, static noise instead [sol
Post by PhilZYX » Sun Apr 17, 2016 10:55 pm
Ok, got it. It was just my crappy little USB audio interface which didn't like 44.1kHz...
