Stuck on Part 4 - No Air Light
Postby cldela0 » Wed Jan 13, 2010 6:25 pm
I am very new to this and am following the build step by step. I have OpenWRT loaded and can talk to the router through the serial connection using ZTerm. I have set both the wireless and network settings identical to the instructions. Problem is that I never get the AIR light to come on. I have been through the forum and tried many of the suggestions to no end. My best guess is that the problem has something to do with my wep key. I have a 2wire router from Windstream that has a 10 digit default wep key written on the barcode. I have tried putting that number in as well as adding 0x to the front of it and still nothing. At this point how would I set up the router if I turned off the encryption (no security)? That would help me narrow the issue down to my wep key or something else. Any help would be greatly appreciated. This looks like a great project, but I can't get the router talking.
Chris
cldela0
Re: Stuck on Part 4 - No Air Light
Postby mightyohm » Wed Jan 13, 2010 11:18 pm
To disable encryption, edit the file /etc/config/wireless.
Edit the "option encryption" line to set encryption to "none" and comment out the wep key, as shown below:
   option device   wl0
   option network   wan
   option mode     sta
   option ssid    <your SSID>
   option encryption none
   #option key <your wep key>
Postby cldela0 » Thu Jan 14, 2010 3:17 pm
Still no luck. Does the fact that my router assigns address 192.168.254.100-200 play a part? I thought dhcp would cover that. Really at a loss. What info can I provide to help troubleshoot the issue?
cldela0
Postby cldela0 » Thu Jan 14, 2010 4:53 pm
Here is the code for both wireless and network as well as a screen shot showing my wireless settings if they will help.
config wifi-device w10
        option type     broadcom
        option channel  4
        option device   wl0
        option network  wan
        option mode    sta
        option ssid    WIN_874
        option encryption wep
        option key     4119627022 #this is the sample key from the manual
        option vlan0    "1 2 3 4 5*"
        option vlan1    "0 5"
        option ifname   "lo"
        option proto    static
        option ipaddr   127.0.0.1
        option netmask  255.0.0.0
        #option type    bridge
        option ifname   "eth0.0"
        option proto  static
        option ipaddr  192.168.1.1
        option netmask  255.255.255.0
routersettings
cldela0
Postby mightyohm » Sat Jan 16, 2010 1:39 am
Try changing the key in /etc/config/wireless from 4119627022 to F58C850E. Save the file, reboot, and see if the router connects.
The IP address should be fine.
Postby cldela0 » Sun Jan 17, 2010 6:26 am
I just stumbled on the error - a typo in the following line "config wifi-device w10". At some point I had mistakenly put a "1" in wlo instead of an "l'. I found the issue when researching the use of "iwlist wl0 scan" to test if any networks were even being picked up. Thanks for all the help.
Chris
cldela0
Postby mightyohm » Sun Jan 17, 2010 10:32 am
Good to hear you have the problem under control now. Sorry I wasn't able to find the problem for you, I wasn't looking in the right place. :D
Postby cldela0 » Sun Jan 17, 2010 1:30 pm
Thanks for giving your time to help novices! Next time a will be sure to watch out for those similar letters :D
cldela0
Postby richms » Sun Jan 24, 2010 12:21 am
Watch the channel too. That had me cursing and swearing for ages about it not working.
richms
Users browsing this forum: Google [Bot], Google Feedfetcher and 0 guests
cron
