It is odd that the audio device works fine when connected directly to the router, but as soon as I place it on the usb hub, it has problems. I will try the audio device and hub on a PC and see what kind of results I get from that.richms wrote:I am using a crap-tastic $1 hub - its the sort that half the time only work as USB1.1, do for me on my desktop PC but on the asus they are fine and do USB2 speeds sweet as.
The xitel USB audio device I have used has a philips chip in it. Not tried the cheapie device since it sounded so bad on the computer I held no hope for it working on the asus.
Could it be the mixer thats the problem? I have to turn it up on the device I have, its about 20dB down by default. No noise tho, but it seems to have had some care in its design to avoid that.
So it sounds like most people that are using an usb hub are not using a powered one. That is a powered hub might not be needed in all cases.
I am planning on connecting an Arduino to my router and wanted to use the USB connection for that.
