Page 2 of 3
Re: Anybody get the 520gU wireless (B43) to work with 2.6 ke
Posted: Tue Jun 29, 2010 9:54 am
Is support for client mode working as well?
Posted: Tue Jun 29, 2010 3:59 pm
by drmoo
mightyohm wrote:Is support for client mode working as well?
Client mode AND WPA2 :D
The only downside is MPD won't fit in the onboard memory. I'll just use a flash drive for that though.
Posted: Sun Aug 15, 2010 11:33 pm
by Roberto
Please let us know the /etc/config/wireless and /etc/config/network necessary for WPA client mode with DHCP.
I just Backfire'd my WL520GU and want to create a media server (ala Pogoplug).
Posted: Thu Aug 19, 2010 5:01 pm
by Roberto
Would you also point me to the instructions to have my rootfs in my flash drive? :P
Posted: Fri Aug 27, 2010 6:36 am
by ilinux
You can try to use a previous version of makefile into mpd folder.
Look for mpd 0.13 for mpc you can use the 0.17 without problems.
I've used this version for last wrtradio firmware
Posted: Sun Oct 09, 2011 1:41 pm
by dddesign
jbemmel wrote:I got Backfire 10.03 (latest release) working on my Asus WL-600G
@jbemmel:
I have also a WL-600G and I'm trying to get usb-audio working with backfire10.03.1rc5 WITHOUT success. I can flash backfire with this file http://downloads.openwrt.org/snapshots/ ... fs-cfe.bin and I have installed package kmod-usb2 and kmod-usb-audio (with all dependencies). but my soundcard http://www.ebay.ch/itm/New-5-1-usb-audi ... 0765333936 is not detected (checked with lsusb). I also tried kmod-usb-ohci and kmod-usb-uhci, no success.
but I know this soundcard can work (with kamikaze and kmod-usb-uhci-iv on an other router (wl-500w))
does your wl-600g support usb-audio? what image did you flash?
thanks for any tips
j
ps: see also my post here: https://forum.openwrt.org/viewtopic.php?id=32117
Posted: Wed Nov 09, 2011 8:53 am
by lostmyshape
This thread might be dead, but I'm hoping someone out there who got this to work is still around. I'd like to mess around with pulseaudio, which can only be built on trunk. So I'm fighting with the 520gu's wireless on 2.6. The prebuilt openwrt image would freeze the router, but, thanks to the thread, I found I could build it myself with CONFIG_B43_STABLE. Now I can enable wireless without the box going haywire.
However, I can't get it to wirelessly connect to my network in client mode with WPA2. A few posts above suggests that this is possible. Could someone with a little more experience help me to troubleshoot? Here are the two config files I've changed after installation:
/etc/config/network:
### VLAN configuration
   option vlan0   "1 2 3 4 5*"
   option vlan1   "0 5"
   option ifname   "lo"
   option proto   static
   option ipaddr   127.0.0.1
   option netmask   255.0.0.0
   #option type    bridge
   option ifname   "eth0.0"
   option proto   static
   option ipaddr   192.168.0.31
   option netmask   255.255.255.0
   option gateway   192.168.0.1
   option dns   8.8.8.8
config interface   wan
   option ifname   "eth0.1"
   option proto   dhcp
/etc/config/wireless:
config wifi-device  radio0
    option type     mac80211
    option channel  11
    option macaddr    xx:xx:xx:xx:xx:xx
    option hwmode    11g
   option device   radio0
   option network   lan
   option mode     sta
   option ssid     MYSSID
   option encryption psk2
   option key MYWEPKEY
After starting wireless with the wifi command I get a weird error:
root@OpenWrt:/# wifi
Error for wireless request "Set Power Management" (8B2C) :
    SET failed on device wlan0 ; Operation not supported.
brctl: bridge br-lan: Operation not supported
brctl: bridge br-lan: File exists
Wireless light is on, but it's not connected to my network. Any ideas? Thank you!
Posted: Fri Nov 11, 2011 10:33 am
by iggyCeltic
I got mine to work with the following setup in the /etc/config/wireless file.
config 'wifi-iface'
	option 'device' 'wl0'
	option 'network' 'lan'
	option 'mode' 'sta'
	option 'ssid' 'SSID'
	option 'encryption' 'mixed-psk+tkip'
	option 'key'  'PASSWORD'
Not sure about your other error yet.
Posted: Sat Nov 12, 2011 8:13 pm
by lostmyshape
I think the other error has to do with a bug that doesn't allow bridge mode with client mode. I've figured a way to get around that, for now. IggyCeltic, would you mind posting your complete /etc/config/network and /etc/config/wireless. I'm getting something wrong here and trying my best to understand these config files...
Posted: Mon Nov 14, 2011 3:50 pm
by iggyCeltic
cat /etc/config/network
	option vlan1	"0 5"
	option ifname	"lo"
	option proto	static
#	option type 	bridge
	option proto	static
	option ipaddr	192.168.1.134
	option gateway  192.168.1.1
	option dns      8.8.8.8
	option proto	dhcp
	option ignore   1
and
cat /etc/config/wireless
config 'wifi-device' 'wl0'
	option 'type' 'broadcom'
	option 'channel' '6'
config 'wifi-iface'
	option 'mode' 'sta'
	option 'ssid' 'MYSSID'
	option 'key'  'MYPASSWORD'
