Troubles with ATtiny85 fuses = 0xFF
Re: Troubles with ATtiny85 fuses = 0xFF
Can you explain what you mean by "Then I am put it in socket and try to re-burn"?
dale
Post by dale »
I mean I am not remove the 328p form socket, then press the button to read the fuse again.
You need to remove the 328P from the socket between fuse writing operations. Can you try removing it from the socket before you attempt to burn the fuses again?
dale
Post by dale »
I have to do it according to your step, but fuse always is 0xFF when first read. maybe these 328P are damage?
That is strange. Do you have another 328p you can try?
dale
Post by dale »
I just have two 328P of DIP package now, when I get new 328P, I will try it again.
OK, please post any updates.
dale
Post by dale »
Hi mightyohm,
I got new 328P, and it always have error, so I trace the PCB,
then find a trace not connect to 328P pin15, so it read/write has error.
This is my problem, because this PCB is make by me.
Thanks your help.
glad to hear you got it sorted out! :ugeek:
