Geiger Kit working at 1300V
Posted: Thu Apr 02, 2015 2:57 pm
As a follow-up to the other thread, just wanted to mention that I've succeeded running Geiger Kit at 1300+ voltage.
In this modification, I've done the following changes:
1) Q1: FJN330F with BUL216: The package is different and leads wouldn't fit into the holes, so it required some ugly soldering. A better approach would have been sanding the leads to make them round and thinner.
2) L1: 10mH with 18mH.
3) D1: 1N4937 with RGP02-20EHE3/54: 2kV rectifier.
4) C1 and C2 with their respective 2kV counterparts.
5) R8: removal, in my case, I've just used 0 Ω resistor instead.
6) VR1: replacing 10 Ω with 100 Ω for higher adjustment range.
7) R5: replaced with 560 Ω.
With above modifications, I could safely get around 1 kV stable output. To be able to get 1300+ voltage, input voltage needs upgrade from 3V to 4.5V. In my case, I've had to solder a different socket for 3 batteries. Doing so, R11 needs to go up to 330 Ω, but I haven't done this change yet (it works without it, albeit LED is a bit bright).
I have attached photo of the kit running at around 1300V. Note that my 10 MΩ multimeter is connected in series with 1 GΩ resistor, so the resulting voltage needs to be multiplied by 100, with roughly 1% of error.
