Screwed up configuration steps...help
Posted: Tue Oct 04, 2011 12:32 am
by shirk
In the final steps of changing the LAN settings I missed commenting out the ipaddr and netmask.
Now I can't telnet back into to try and fix it. When I attempt a telnet I keep getting "Unable to connect to remote host" errors.
Is there something I can do??? Hope I didn't somehow lock it into a brick.
Re: Screwed up configuration steps...help
Posted: Tue Oct 04, 2011 8:02 am
by shirk
Ignore my 1:30 am panic. I did a hard reset and reloaded DD-WRT image. All is good this morning. No brick.
Tonight after work I do the config and follow the instructions a lot closer.
Posted: Tue Oct 04, 2011 10:45 am
by gerben
OpenWRT has a failsafe mode. See
http://wiki.openwrt.org/toh/asus/wl520gu#failsafe.mode . Although they refer to a DMZ led, that the wl520gu doesn't have.
Also here on this forum;
viewtopic.php?t=158&f=2 ; but he didn't get it to work (try pressing repeatedly instead of holding it as he is doing. Might work.)
Posted: Thu Oct 06, 2011 11:36 pm
by shirk
Okay I have finally gotten further along on it.
I have the router configured and it's connecting to my wireless network. I was able to install the usd-audio software.
But I can't seem to log back in after the reboot step. Everything was going along fine, not I keep getting time out errors trying to log back in.
I think I'll cycle the power once and leave it overnight and try again in the am. Finicky thing this is.
Posted: Fri Oct 07, 2011 7:20 am
by shirk
This morning it let me in. Finished the mpd and mpc install.
Now fully up and running. Woot woot.
Thank you for the work you've put into your site for the tutorial.
