I can not change the fuses
brunortt
Post by brunortt »
I try to change the fuses No change
Do I have to feed the HV Rescue Shield 2. with 12V?
Any suggestions?
Thanks.
Re: I can not change the fuses
Hi brunortt,
Sorry for the delay in my reply.
The rescue shield contains its own 12V supply so you do not need to provide one.
Can you tell me more about what chip you are trying to use with the shield? Was the chip working normally before? What version of the Arduino sketch are you using, and what version of Arduino?
Make sure the chip is inserted with pin 1 in the correct location as it seems like the chip is not responding.
brunortt
Post by brunortt »
Hi mightyohm,
Thanks for answering
The chip on the ATMEGA328P
The chip worked fine, and when I try to load a program no longer responds
Arduino version is 1.6.5 and I tried both version of the sketch Arduino Uno as Arduino Mega, with the same result as seen in the image above
I see that you are using an Arduino MEGA. Did you set #define MEGA 1 in the Arduino sketch?
http://mightyohm.com/blog/2011/03/hv-re ... uino-mega/
brunortt
Post by brunortt »
Hi mightyohm,
Set the MEGA #define to 1 and compile/upload the sketch to your board
But as usual
After changing MEGA to 1, did you remove the ATMEGA328 from the rescue shield before clicking the "Upload" button in the Arduino IDE?
It seems like maybe the change in code did not get compiled and uploaded to the board. The behavior you are seeing (fuses = 3) can happen if the code running on the Arduino is not compiled for the Mega.
Other things to try -Check all of your solder joints. Try the shield with an Arduino Uno if you have one around - most of my testing has been done with the Uno. Make sure the ATMEGA328 is not plugged into the socket when you upload the sketch or open the serial monitor. Try a spare ATMEGA328 if you have one to make sure the chip isn't bad.
I just verified that the shield works with the latest Arduino IDE (1.6.5) and both the Uno and a Mega 2560. Everything seems to be working fine here.
brunortt
Post by brunortt »
Hi mightyohm,
I tried it with a new chip (ATMEGA328P), and I changed the fuses seamlessly
So the compilation and communication with arduino is correct for the mega
But that I can do with a programmer (USBtiny)
I think the HV Shield Rescue 2 is not working on high voltage (HVPP)
The rescue shield uses a completely different protocol from avrdude so if it works on one part, the 12V HVPP must be working. Most likely the first chip you tried is damaged somehow.
