programming an atmega48
captainssbn
Postby captainssbn » Mon Feb 15, 2016 2:24 pm
Hi all I need help programing the atmega48 with the code provided from avr448 which is the code to run a 3 phase HV motor. I have a usbtinyisp device and have successfully down loaded the driver. I have been using codevision to compile the code successfully it found one error PCINT1 which needed to be changed to PC_INT1.
How can I down load the file to the atmega48? If someone has done this provide me with easy to follow instruction I'll give you a pcb for helping.
Gary
Return to “General Discussion”
