TL-MR3020: radio stream stops, static noise instead
Posted: Wed Apr 13, 2016 12:45 am
Hi there,
I have set up a little wifi radio with a TP Link TL-MR3020, running MPD on OpenWRT Barrier Breaker. Everything works fine except that every now and then the stream turns into static / white noise at full volume. When i stop and restart the stream it works fine again.
Has anyone had the same problem? Maybe a internet connection issue? Or too little RAM?
Cheers,
Philipp
Cheers,
Philipp
