Creative Tactic Alpha USB sound card doesn't work
velja
Postby velja » Wed Aug 10, 2016 8:03 am
My first post and the problem. I configure ASUS wl-520gU for wifi radio but this sound cart can't give any tone. Do I miss something? Here is partial log from serial port:
SB USB20H init
SB COREREV: 2
SB USB20H resetting
USB20H fcr: 0x64
USB20H shim cr: 0x8f7
hub.c: USB hub found
hub.c: 2 ports detected
hub.c: new USB device 00:03.0-1, assigned address 2
usbaudio: device 2 audiocontrol interface 0 has 1 input and 1 output AudioStreaming interfaces
usbaudio: device 2 interface 2 altsetting 1 channels 1 framesize 2 configured
usbaudio: valid input sample rate 44100
usbaudio: device 2 interface 2 altsetting 1: format 0x00000010 sratelo 44100 sratehi 44100 attributes 0x00
usbaudio: device 2 interface 1 altsetting 0 does not have an endpoint
usbaudio: device 2 interface 1 altsetting 1 channels 2 framesize 2 configured
usbaudio: valid output sample rate 44100
usbaudio: device 2 interface 1 altsetting 1: format 0x01000010 sratelo 44100 sratehi 44100 attributes 0x00
usbaudio: device 2 interface 1 altsetting 2 channels 2 framesize 3 configured
usbaudio: device 2 interface 1 altsetting 2: format 0x01000800 sratelo 44100 sratehi 44100 attributes 0x00
usbaudio: registered dsp 14,3
velja
Re: Creative Tactic Alpha USB sound card doesn't work
Postby velja » Wed Aug 10, 2016 8:16 pm
So, I open USB device and found Conexant CX20562 chip inside. Wheh I installed opkg package for USB I install only kmod-usb-audio and kmod-usb-ohci. When I stat mpc play I get message that it play but nothing come out. I done everything as it described in Part5 of instruction and get all response as it written but no sound. This sound card work when I connect to laptop/
Return to “Wifi Radio Project / Hacking the Asus WL-520gU”
Users browsing this forum: Google [Bot] and 2 guests
