My finished WiFi internet radio
velja
Post by velja » Thu Aug 25, 2016 2:23 am
So, after resolving some issues I finish my radio. Here is the link.
https://www.youtube.com/watch?v=EquU11orYT8
I use ASUS WL-520gU router and controll it with AVR MEGA8 MCU. Software is written in BASCOM AVR.
Re: My finished WiFi internet radio
Post by mightyohm » Sat Aug 27, 2016 5:52 pm
Very nice work, thanks for sharing!
velja
Post by velja » Tue Sep 06, 2016 12:48 am
Here is source :
' Finished version. ATMEGA8, LCD 16x2
' 28 august 2016
$regfile = "m8def.dat"
$crystal = 8000000
$baud = 9600
$hwstack = 64
$swstack = 64
$framesize = 64
Config Adc = Single , Prescaler = 8 , Reference = Avcc
Config Serialin = Buffered , Size = 128
Dim Adc_old As Word , Adc_new As Word , Adc_malo_old As Word , Adc_malo_new As Word
Dim Nm As String * 1
Dim Temp_buffer As String * 128
Dim Name_buffer As String * 40
Dim Title_buffer As String * 40
Dim Temp_str As String * 4
Dim Start_string1 As String * 14
Dim Start_string2 As String * 14
Dim C As Byte , I As Byte , Pointer As Byte , Duzina As Byte , Duzina_i As Byte , Duzina_t As Byte
Dim Name_pos As Byte , Title_pos As Byte , Visak As Byte , Visak_i As Byte , Visak_t As Byte , Visak_new As Byte
Dim Pos As Byte
Declare Sub Adc_read
Declare Sub Shift_lcd
Config Lcdpin = Pin , Rs = Portd.2 , E = Portd.4 , Db4 = Portc.0 , Db5 = Portc.1 , Db6 = Portc.2 , Db7 = Portc.3
Config Lcd = 16 * 2
Cls
Cursor Off
Enable Interrupts
Lcd " WI FI INTERNET "
Lowerline
Lcd " RADIO "
Wait 2
Cls
Lcd "Velja Cvetkovic "
Lowerline
Lcd " 2016 "
Wait 5
Cls
Lcd "Inicijalizacija "
Lowerline
Lcd " rutera... "
Wait 40
Adc_old = 10
Start Adc
Cls
Wait 2
'******** Start detection: "AVR Start!\n"
Temp_buffer = ""
Do
Do
If Ischarwaiting() = 1 Then
Nm = Inkey()
If Len(temp_buffer) < 13 Then Temp_buffer = Temp_buffer + Nm
If Len(temp_buffer) = 13 Then Temp_buffer = Temp_buffer + Chr(13)
End If
Loop Until Ischarwaiting() = 0
Pos = Instr(temp_buffer , "AVR Start" )
Loop Until Pos <> 0
Main:
Do
Gosub Adc_read
L1:
Gosub Citanje 'Reading
Gosub Ekstrakcija 'Extraction
Temp_buffer = ""
Gosub Shift_lcd
Loop
End
Ekstrakcija:
Name_buffer = ""
Title_buffer = ""
Name_pos = Instr(temp_buffer , "Name: " )
Title_pos = Instr(temp_buffer , "Title: ")
Name_pos = Name_pos + 6
Duzina = 0
Do
Incr Duzina
Pointer = Name_pos + Duzina
Temp_str = Mid(temp_buffer , Pointer , 1)
Loop Until Temp_str = Chr(13) Or Temp_str = ""
If Duzina > 40 Then Duzina = 40
Name_buffer = Mid(temp_buffer , Name_pos , Duzina)
Visak_i = Len(name_buffer)
Title_pos = Title_pos + 7
Duzina = 0
Do
Incr Duzina
Pointer = Title_pos + Duzina
Title_buffer = Mid(temp_buffer , Title_pos , Duzina)
Visak_t = Len(title_buffer)
Return
Citanje:
Temp_buffer = ""
Do
Nm = Inkey()
If Len(temp_buffer) < 127 Then Temp_buffer = Temp_buffer + Nm
If Len(temp_buffer) = 127 Then Temp_buffer = Temp_buffer + Chr(13)
End If
Return
Sub Adc_read:
Adc_new = Getadc(4)
Adc_malo_old = Adc_old / 10
Adc_malo_new = Adc_new / 10
If Adc_malo_new <> Adc_malo_old Then
Adc_old = Adc_new
Print "tuner: " ; Adc_new
End If
End Sub
'*** Shifting: If text is longer then 16 character scroll to the left and stop
' when last character of longer line was displayed
Sub Shift_lcd:
Dim A As Byte
If Visak_i > Visak_t Then
Visak = Visak_i
Else
Visak = Visak_t
End If
If Visak > 16 Then
Visak_new = Visak - 16
End If
Cls
Lcd Name_buffer
Lowerline
Lcd Title_buffer
Wait 1
Goto Double_check
Wait 1
Goto Double_check
If Visak > 16 Then
Goto Lcd_shift
End If
End Sub
Lcd_shift:
For A = 1 To Visak_new
Shiftlcd Left 'shift the text to the right
Waitms 250
Goto Double_check 'wait a moment
Next
Wait 1
Return
Double_check:
Adc_new = Getadc(4)
Adc_old = Adc_new
Goto L1
End If
Return
