Powering Multiple Units
jmorri36
Post by jmorri36 » Wed Jul 25, 2018 6:51 pm
Do I need to use separate power supplies when power multiple units through the 3v battery input?
I currently have six hooked up and tested. They all work great separately, but I'm not sure they're functioning properly when they have the same 3v power supply. Sometimes I'll see/hear about four tubes activate at the same time. Is that normal and to be expected? Or am I getting noise on the line from the shared power supply?
Thanks!
Re: Powering Multiple Units
Post by mightyohm » Wed Jul 25, 2018 10:05 pm
I've done this before and haven't had an issue. It should work fine. It's possible that you are detecting cosmic rays that are triggering more than one tube at a time, although if the tubes are far separated this is unlikely.
