using re-set PIN on attiny85
Ktronik
Post by Ktronik »
Hey Guys,
just got my HV shield....as a 'learn to use' step...I want to use the re-set pin on the Attiny85
the fuse CAL tells me I need to set:
Low:0XE2
High:0x7F
Ext:0xFF
I also see this: set High Fuses to 0x5f rather than 0xdf, to set the RSTDISBL fuse.
please can I ask your preferred method on your HV shield I now have???
once I build it I will get in there and try too see what works...
I can assume I just set High fuse back to default to get re-set pin back again...
thx again for the kit!!!
Ktronik
Ktronik
Re: using re-set PIN on attiny85
Post by Ktronik »
found my answers....putting here for REF
so default... is actually....'Serial program downloading (SPI) enabled; [SPIEN=0] * ON'
RSTDISBL fuse is actually, High:0x7F, mixed with the default of SPIEN on....we get
High Fuses to 0x5f rather than 0xdf.....as df = default.
so in my case...using 5f is fine to use...
Glad you got it working. Let me know if I can help with anything else!
