resources:cd101
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revisionLast revisionBoth sides next revision | ||
resources:cd101 [01/12/2011 19:52] – [User Manuals] jeff | resources:cd101 [02/02/2011 22:33] – davidpincus | ||
Line 4: | Line 4: | ||
Available from [[http:// | Available from [[http:// | ||
+ | The unit I received has two control outputs, SSR (OUT1) and RELAY (OUT2) and is labeled: | ||
+ | |CODE | ||
+ | |RANGE | ||
+ | |INPUT | ||
+ | |OUTPUT |SSR RELAY| | ||
Examples of this controller in use: | Examples of this controller in use: | ||
- | * Keith used this one in his [[http:// | + | * Keith used this one in his [[http:// |
* Make: volume 25 includes a [[http:// | * Make: volume 25 includes a [[http:// | ||
* The Make article is based on [[http:// | * The Make article is based on [[http:// | ||
Line 14: | Line 21: | ||
* [[http:// | * [[http:// | ||
- | * [[http:// | + | * [[http:// |
+ | * This includes information about the "meter parameter mode" or " | ||
===== Undocumented Settings / Features ===== | ===== Undocumented Settings / Features ===== | ||
Line 27: | Line 35: | ||
* SL 2 = 0001 sets the unit to display all temperatures in Fahrenheit | * SL 2 = 0001 sets the unit to display all temperatures in Fahrenheit | ||
* SL 6 = 0001 disables OUT2 (the relay output) and stops the audible clicking associated with it | * SL 6 = 0001 disables OUT2 (the relay output) and stops the audible clicking associated with it | ||
+ | * SL10 = 0001 enable STOP mode (which doesn' | ||
+ | * SL10 = 1000 enable ST (Self Tune) mode - makes ST appear in the menus | ||
Line 33: | Line 43: | ||
* Pressing the R/S button for 2 sec results in STOP being shown on the upper display, but the outputs continue to function. | * Pressing the R/S button for 2 sec results in STOP being shown on the upper display, but the outputs continue to function. | ||
+ | ===== Photos ===== | ||
+ | Photos of CD101 disassembly thanks to [[http:// | ||
resources/cd101.txt · Last modified: 02/23/2011 06:13 by davidpincus
