resources:cd101
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
resources:cd101 [01/12/2011 19:53] – [User Manuals] jeff | resources:cd101 [02/23/2011 06:13] (current) – davidpincus | ||
Line 4: | Line 4: | ||
Available from [[http:// | Available from [[http:// | ||
+ | The unit I received has two control outputs, SSR (OUT1) and RELAY (OUT2) and is labeled: | ||
+ | |CODE | ||
+ | |RANGE | ||
+ | |INPUT | ||
+ | |OUTPUT |SSR RELAY| | ||
Examples of this controller in use: | Examples of this controller in use: | ||
- | * Keith used this one in his [[http:// | + | * Keith used this one in his [[http:// |
* Make: volume 25 includes a [[http:// | * Make: volume 25 includes a [[http:// | ||
* The Make article is based on [[http:// | * The Make article is based on [[http:// | ||
Line 24: | Line 31: | ||
These settings can be accessed by holding SET and < at the same time for 3s, then setting Cod to 0000. More information is available in the 2nd user manual given above. | These settings can be accessed by holding SET and < at the same time for 3s, then setting Cod to 0000. More information is available in the 2nd user manual given above. | ||
* SL 1 sets the input type, defaults is K-type thermocouple. | * SL 1 sets the input type, defaults is K-type thermocouple. | ||
- | * I haven' | + | * I haven' |
* SL 2 = 0000 sets the unit to display all temperatures in Celsius | * SL 2 = 0000 sets the unit to display all temperatures in Celsius | ||
* SL 2 = 0001 sets the unit to display all temperatures in Fahrenheit | * SL 2 = 0001 sets the unit to display all temperatures in Fahrenheit | ||
* SL 6 = 0001 disables OUT2 (the relay output) and stops the audible clicking associated with it | * SL 6 = 0001 disables OUT2 (the relay output) and stops the audible clicking associated with it | ||
+ | * SL10 = 0001 enable STOP mode (which doesn' | ||
+ | * SL10 = 1000 enable ST (Self Tune) mode - makes ST appear in the menus | ||
Line 34: | Line 43: | ||
* Pressing the R/S button for 2 sec results in STOP being shown on the upper display, but the outputs continue to function. | * Pressing the R/S button for 2 sec results in STOP being shown on the upper display, but the outputs continue to function. | ||
+ | ===== Photos ===== | ||
+ | Photos of CD101 disassembly thanks to [[http:// | ||
resources/cd101.txt · Last modified: 02/23/2011 06:13 by davidpincus
