Both sides previous revision Previous revision | |||
resources:cd101 [02/02/2011 22:33] davidpincus |
resources:cd101 [02/23/2011 06:13] (current) davidpincus |
Line 31: | Line 31: | ||
These settings can be accessed by holding SET and < at the same time for 3s, then setting Cod to 0000. More information is available in the 2nd user manual given above. | These settings can be accessed by holding SET and < at the same time for 3s, then setting Cod to 0000. More information is available in the 2nd user manual given above. | ||
* SL 1 sets the input type, defaults is K-type thermocouple. Chart in 2nd manual listed above. | * SL 1 sets the input type, defaults is K-type thermocouple. Chart in 2nd manual listed above. | ||
- | * I haven't verified that other inputs actually function correctly, but Scott's Sous Vide cooker uses a PT100 sensor and it apparently works. | + | * I haven't verified that other inputs actually function correctly, but Scott's Sous Vide cooker uses a PT100 sensor and it apparently works. UPDATE: SL1=1100 setting for PT100 changes the display to include one decimal point. //David 23/02/2011 // |
* SL 2 = 0000 sets the unit to display all temperatures in Celsius | * SL 2 = 0000 sets the unit to display all temperatures in Celsius | ||
* SL 2 = 0001 sets the unit to display all temperatures in Fahrenheit | * SL 2 = 0001 sets the unit to display all temperatures in Fahrenheit |
