soldercomic
Differences
Both sides previous revisionPrevious revision | |||
soldercomic [04/16/2011 09:47] – lifehacker jeff | soldercomic [04/16/2011 09:52] (current) – email jeff | ||
Line 1: | Line 1: | ||
====== Solder Comic Feedback ====== | ====== Solder Comic Feedback ====== | ||
+ | ===== Web ===== | ||
[[http:// | [[http:// | ||
Line 98: | Line 100: | ||
**eubarch: | **eubarch: | ||
Also doesn' | Also doesn' | ||
+ | ===== E-mail: ===== | ||
+ | **flink:** It's a nice guide for beginners. I know that many people are intimidated by soldering. It's a kind of esoteric knowledge and skill for many people. Well, for most people, I guess. | ||
+ | As you prepare the tips and advice section for the next guide, please add a little cross-section diagram depicting a lead passing through the hole with a concave filet of solder joining pad to the lead on both sides. It's easier to get people doing it right if they know exactly what to shoot for when making a good joint. | ||
+ | A purely technical note, also explain that the solder is actually bonding metal to metal similar to welding with a brazing rod. A few people I've taught thought solder worked like glue. :-) | ||
+ | Also, to remove the solder, it's probably better to explain how to use solder wicking mesh (" | ||
+ | I hope you don't mind me butting it with advice. I worked in a few micro-miniature repair facilities (solder shops) while I was in the service. I'm always heartened by seeing younger people hacking at things. It's good that someone is doing it. | ||
soldercomic.1302947271.txt.gz · Last modified: 04/16/2011 09:47 by jeff
