MEGA ADK
mdn15
MEGA ADK
Post by mdn15 »
I cannot seem to get the HV Rescue Shield 2.1 to work with the MEGA ADK. Is it incompatible. it has the same processer as the Arduino Mega?
More specifically, I can load the Sketch (and yes I have modified the flags to say that Im using a Mega), but I cannot get interactive or automatic modes to work.
Any advice or help would be greatly appreciated.
Regards
Re: MEGA ADK
Do you have the Rescue Shield installed as shown here?
http://mightyohm.com/blog/2011/03/hv-re ... uino-mega/
Do you have a regular Mega or Uno around that you can test with to make sure your Rescue Shield is working?
Also, double-check the baud rate setting in the serial monitor. It should be set to 9600 baud.
