USB-audio adapters known to work with OpenWrt/mpd
Re: USB-audio adapters known to work with OpenWrt/mpd
Wanted to contribute to this inspiring project...
I confirmed that the following two USB devices works:
Creative Labs M-MOD works - http://www.amazon.com/Creative-Labs-Xmo ... 022&sr=8-2
Logitech USB Laptop Speaker Z305 - http://www.amazon.com/Logitech-USB-Lapt ... B003VAK1I2
The volume up/down button on the device doesn't work though.
Those buttons are usb hid buttons for sure. To making it work you should install the USB HID kernel module, and then use an application like triggerhappy to associate buttons with commands.grayman4hire wrote: The volume up/down button on the device doesn't work though.
I just got a couple of these the other day. They play, but the sound drops out every few seconds for me. Other kinds I've tried do work, so I know it's not just my own setup that is causing it...sail4sea wrote:I ordered a bunch of these. TInkernut suggested them.
http://www.amazon.com/External-Channel- ... B000N35A0Y
I got them for $.19 a few days ago. The price has gone up to $.23 though.
I've got one of these: http://www.ebay.com/itm/MUSE-HIFI-USB-t ... 1c282a01e8
It works perfectly on a PC running Windows 7 but it is not perfect on the router (OpenWrt with mpd), I hear some 'static' noise (like the noise on a vinyl record). I've played with the sampling rate conversion on mpd (44.1kHz and 48kHz), configured the interface as alsa and as oss, changed the interpolator for "Best Sinc Interpolator", also played with buffer sizes, but the problem remains the same. CPU usage is low (typically bellow 10%), and there is still free memory and the swap space is not even used. Any suggestion on this problem?
Fernando
Fernando
SteelSeries Siberia 5H V2 USB
Gigatech GSC-U02, which is one of the "Virtual 5.1 Channel USB Sound Card Adapter" clones for 2-3$. Both C-media based
TP-Link TL-WR703N running Attitude Adjustment 12.09
I bought one from Frys:
http://www.frys.com/product/6560623?sit ... IN_RSLT_PG
The link to the manufacturer (in case Fry's no longer sells this):
http://www.sabrent.com/category/audio/USB-SBCV/
Until now, I could not find what chipset this sound card has. I don't have another one to compare with, but I can confirm that sound quality is good, no clicks or pops. I have it connected to a Tp-Link TL-WR703N portable router, playing madplay. Just plug and play, no other changes necessary.
- Attachments
- sabrent.jpg (16.06 KiB) Viewed 308846 times
Can anybody use hw volume buttons of this sound adapter? I use Asus WL-500gP v2 with MightyOhm's firmware.claus14 wrote:I bought one from Frys:
Hi fecus,
I have this adapter connected to a TP-Link TL-WR703N portable router, playing madplay. The hw buttons don't work, with my configuration. I have a set of speakers with volume control, so this is not an issue for me, I can control the volume directly from the speakers. Hope this helps.
claus14
claus14
Hi claus14,claus14 wrote:Hi fecus,
claus14
Thanks. Yes it helps. My construction will be the same as yours. I don't force digitally solution of volume control.
FYI, the Syba SD-CM-UAUD USB Stereo Audio Adapter, C-Media Chipset (http://www.amazon.com/gp/product/B001MSS6CS) works with OpenWrt, at least the Kamakazi build on the MightyOhm site. I'm using it with a WL-500gP v2 and haven't encountered any problems so far.
