Inductor specs
bratan
Inductor specs
Post by bratan »
I want to build a higher voltage version with 15mH inductor. But I don't know anything else about inductor, i.e. what tolerance should it be or maximum current. Anyone knows? Also source would be great, I wasn't able to find anything thru the hole on eBay :(
Re: Inductor specs
Try Digi-Key, Mouser, or Farnell.
You'll need a higher voltage switching transistor if you want to go much over 400V.
See this post: viewtopic.php?f=15&t=496
Re: Inductor specs
