Page 2 of 2
Re: Troubles with ATtiny85 fuses = 0xFF
Posted: Wed Dec 02, 2015 7:03 pm
Can you explain what you mean by "Then I am put it in socket and try to re-burn"?
Posted: Thu Dec 03, 2015 9:47 am
by dale
I mean I am not remove the 328p form socket, then press the button to read the fuse again.
Posted: Thu Dec 03, 2015 10:19 am
You need to remove the 328P from the socket between fuse writing operations. Can you try removing it from the socket before you attempt to burn the fuses again?
Posted: Thu Dec 03, 2015 9:37 pm
by dale
I have to do it according to your step, but fuse always is 0xFF when first read. maybe these 328P are damage?
Posted: Thu Dec 03, 2015 11:27 pm
That is strange. Do you have another 328p you can try?
Posted: Fri Dec 04, 2015 8:37 am
by dale
I just have two 328P of DIP package now, when I get new 328P, I will try it again.
Posted: Sun Dec 13, 2015 4:41 pm
OK, please post any updates.
Posted: Fri Jan 01, 2016 1:58 am
by dale
Hi mightyohm,
I got new 328P, and it always have error, so I trace the PCB,
then find a trace not connect to 328P pin15, so it read/write has error.
This is my problem, because this PCB is make by me.
Thanks your help.
Posted: Fri Jan 01, 2016 12:07 pm
glad to hear you got it sorted out!
