OPKG url invailed
Jeff_
OPKG url invailed
Post by Jeff_ »
each time i type opkg update i get the following error:
root@OpenWrt:/# opkg update
Downloading http://mightyohm.com/files/kamikaze-2.4/packages/mipsel/Packages/Pac
kages.gz
wget: bad address 'mightyohm.com'
Signiture check for snapshots skipped because GPG support was not enabled in thi
s build
Collected errors:
 * opkg_download: ERROR: Command failed with return value 1: `wget --passive-ftp
    -P /tmp/opkg-fVoDTC http://mightyohm.com/files/kamikaze-2.4/packages/mipsel/
Packages/Packages.gz'
root@OpenWrt:/#
what does it means ,that it needs a passive ftp connection or ..?
the config:
src/gz snapshots http://mightyohm.com/files/kamikaze-2.4/packages/mipsel/Packages/mipsel
dest root /
dest ram /tmp
lists_dir ext /var/opkg-lists
[URL=http://www.speedtest.net][IMG]http://www.speedtest.net/result/1322220679.png[/IMG][/URL]
Re: OPKG url invailed
Jeff_ wrote:
dest root /
dest ram /tmp
You have packages/mipsel in your URL twice. The correct URL is: http://mightyohm.com/files/kamikaze-2.4 ... es/mipsel/
Jeff_
Post by Jeff_ »
allready found out that it was misspelled,do you know if I can use the atmega 328 for the display ?
Found a complete kit on eBay: http://www.ebay.com/itm/Arduino-Starter ... 0627362140
Also I can't get it connected to my wpa/wpa2psk network,only if I make it insecure then it connects.
Post by jeroen94704 »
You should be able to make this work using an Arduino, but I believe you won't be able to reuse the code Jeff published, since Arduino uses its own toolchain (I have no Arduino experience though, so I could be mistaken).
Someone on the forums wrote an Arduino version of the display program. Do a search and let me know if you can't find it.
It should also be pretty simple to port the existing C code over to the 328.
nakarmkir
Post by nakarmkir »
Hello.
Where are that arduino display code and schematics?
Thanks in advance
Andrew92
Post by Andrew92 »
nakarmkir wrote:
Thu Sep 02, 2021 10:25 pm
Hello.
Thanks in advance
this thread has been inactive for a while but I was hoping to find out the same thing?
