using re-set PIN on attiny85
Posted: Tue Jan 08, 2019 2:02 pm
Hey Guys,
just got my HV shield....as a 'learn to use' step...I want to use the re-set pin on the Attiny85
the fuse CAL tells me I need to set:
Low:0XE2
High:0x7F
Ext:0xFF
I also see this: set High Fuses to 0x5f rather than 0xdf, to set the RSTDISBL fuse.
please can I ask your preferred method on your HV shield I now have???
once I build it I will get in there and try too see what works...
I can assume I just set High fuse back to default to get re-set pin back again...
thx again for the kit!!!
Ktronik
Low:0XE2
High:0x7F
Ext:0xFF
Ktronik
