Differences
| Both sides previous revision Previous revision Next revision | Previous revision | ||
| resources:cd101 [01/21/2011 00:07] – added note to keith's link jeff | resources:cd101 [02/23/2011 06:13] (current) – davidpincus | ||
| Line 31: | Line 31: | ||
| These settings can be accessed by holding SET and < at the same time for 3s, then setting Cod to 0000. More information is available in the 2nd user manual given above. | These settings can be accessed by holding SET and < at the same time for 3s, then setting Cod to 0000. More information is available in the 2nd user manual given above. | ||
| * SL 1 sets the input type, defaults is K-type thermocouple. | * SL 1 sets the input type, defaults is K-type thermocouple. | ||
| - | * I haven' | + | * I haven' |
| * SL 2 = 0000 sets the unit to display all temperatures in Celsius | * SL 2 = 0000 sets the unit to display all temperatures in Celsius | ||
| * SL 2 = 0001 sets the unit to display all temperatures in Fahrenheit | * SL 2 = 0001 sets the unit to display all temperatures in Fahrenheit | ||
| * SL 6 = 0001 disables OUT2 (the relay output) and stops the audible clicking associated with it | * SL 6 = 0001 disables OUT2 (the relay output) and stops the audible clicking associated with it | ||
| + | * SL10 = 0001 enable STOP mode (which doesn' | ||
| + | * SL10 = 1000 enable ST (Self Tune) mode - makes ST appear in the menus | ||
| Line 41: | Line 43: | ||
| * Pressing the R/S button for 2 sec results in STOP being shown on the upper display, but the outputs continue to function. | * Pressing the R/S button for 2 sec results in STOP being shown on the upper display, but the outputs continue to function. | ||
| + | ===== Photos ===== | ||
| + | Photos of CD101 disassembly thanks to [[http:// | ||
