products:hvrescue:compatibility
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
products:hvrescue:compatibility [12/06/2010 23:13] – jeff | products:hvrescue:compatibility [12/14/2010 16:52] (current) – jeff | ||
Line 1: | Line 1: | ||
- | Microcontrollers known to work with the [[http:// | + | Microcontrollers known to work with the [[http:// |
+ | This list is in progress and by no means complete. | ||
- | Hardware versions < 2.0: | + | If you have good results with a device that is not listed, please consider adding it. |
+ | Hardware versions < 2.0 (the original version of the shield): | ||
* ATmega48/ | * ATmega48/ | ||
- | * ATmega328P | + | * ATmega48P/ |
- | * ATtiny2313 | + | * ATmega48PA/ |
+ | * ATtiny2313 | ||
- | Hardware versions >= 2.0 | + | Hardware versions >= 2.0 (the HV Rescue Shield 2, with 3 IC sockets): |
* All microcontrollers shown above for the original hardware | * All microcontrollers shown above for the original hardware | ||
* ATtiny13A | * ATtiny13A | ||
- | * ATtiny85 | + | * ATtiny25/ |
+ | * most 8-pin ATtiny microcontrollers should be supported, since they share the same HVSP protocol | ||
+ | * if you have tested a part not listed here, please consider adding it to the list! | ||
+ | Note: Not all ATtiny parts have an EFUSE. | ||
products/hvrescue/compatibility.1291677204.txt.gz · Last modified: 12/06/2010 23:13 by jeff
