Tony’s Diamond Chop Saw (Part 3)
Welcome to Part 3 of the Diamond Chop Saw build.  In this installment I’m going to focus on the construction of the mechanical aspects of the saw structure, motor attachment, vacuum chuck, and splash guard.   This is a  picture-heavy entry…
After thinking for a while about how to build the saw, I decided that it would be best to have the blade move only in the vertical axis, and the workpiece move horizontally in two axes.   This led to the overall machine design which consists of a vertical column with pivoting cutting head assembly, and a workpiece holder that has two axes of horizontal motion.
Completed Dicing Saw
I wanted to ensure the motor and blade had a rigid, heavy mounting structure to reduce effects of vibration and flex on cutting performance.  I decided to mount the motor using the original mounting flange from the hard drive enclosure since it was nicely machined to match the motor flange.  I used a hacksaw to cut out the shape roughly to size, then straightened up the edges and machined a mounting recess on my milling machine.  The L-shaped piece of aluminum is 1/2 inch thick which gives lots of weight and provides sufficient thickness for mounting the bearing while preventing motion orthogonal to the bearing axis.
Cutting Head Assembly
Another view of the cutting head assembly.  In the upper left hand corner is the pivot bearing.  The bearing is held in place with a set screw that goes through the L-shaped aluminum piece.  Along the bottom edge of the black hard drive enclosure portion I attached a strip of white LEDs to help light the work area.  RTV Siliconeis used to seal the electrical contacts from water that migt not be caught by the splash shield.  At the lower left hand corner of the aluminum plate is a rounded off screw.  The cutting depth adjustment micrometer pushes against this rounded off screw.  Pushing against the aluminum would be less accurate (aluminum would become unevenly worn).
892
Cutting head assembly (rear view)
At the top of the column on either side is a hole for the screws that hold the pivot bearing (also from a hard drive) in place.   Luckily the one I used has 4-40 threaded holes on either side.  A screw on each column holds the bearing in place, and then the rest of the column assembly and adjustment plate are attached resulting in a good alignment of the column to the bearing.
Pivot bearing/column mounting detail
Controlling the depth of the cut is critical, as my cuts will be as small as 5 thousandths of an inch deep!  I mounted a micrometer head to a plate on the back of the column which controls the height of the cutting head assembly.
Rear view of the column and depth adjustment control
 Now for a little detail on the vacuum chuck… The chuck is made from two 1/4 inch plates of aluminum.  The top surface has a shallow set of trenches cut to distribute the suction across the bottom surface of the glass plate used for holding parts.  The lower plate has a deep trench cut in it to distribute the suction to the three small holes drilled on the top plate.  The whole thing is held together with screws and sealed with silicone.  I made a set of hose barbs (one is pictured below) so that I can use 1/8 inch vinyl tubing to connect to my vacuum pump.  The barbs were made by turning down 10-32 stainless steel screws on my lathe.
Lower half of vacuum chuck with custom-made hose barb
  The last major component of the saw is the splash guard.  This actually took a fair amount of effort to make, as I broke pieces more than once and had to start over.  Essentially it is a two-piece design with a thick piece screwed to the cutting head assembly, and a thinner piece which screws onto the first.  I used a heat gun to soften the plastic and carefully mold it to the shape of the face plates.  I then glued the curved section and the outer face plate together using epoxy and while not very pretty, it holds together well.
Splash guard on the saw
That pretty much sums up the mechanical aspects of the saw construction.  Next week I’ll post the 4th and final installment which will include alignment and attachment of the blade, and actual use of the saw!
