Hexbright Hacking
The Hexbright is an Arduino-compatible open source flashlight that was the subject of a very successful kickstarter campaign in 2011.
Today I spent a short time working on some custom firmware for it.
My firmware adds two new features:
  • Button presses cycle between modes (low, med, high brightness) as usual, but if you wait longer than CYCLE_DELAY (default 5 seconds) between presses, the next press turns the hexbright off.
  • If the hexbright is left on for longer than AUTO_OFF_MINUTES (defaults to an hour), the hexbright turns off.  Handy for when you prop the light somewhere and forget about it.
You can download my custom Hexbright Arduino sketch here.  If you’re new to the Hexbright, read these well-written instructions first.  You’ll need to install the required USB driver and Arduino board configuration file.
Amazon link: HexBright FLEX, 500 Lumen Programmable LED Flashlight
2 thoughts on “Hexbright Hacking”
  1. I did something similar to the button press thing, If you press the button for more than 750 ms it will turn off, less than that cycles the mode.
Your email address will not be published. Required fields are marked *
