Environmental Activism meets High Power Lasers!
January 19th, 2009 by JeffNeat art installation in Helsinki displays laser images on the smoke plume of a power plant.
Maybe we could convince them to make the world’s largest oscilloscope now that they’re done?
Inhabitat » Nuage Vert “Green Cloud” Illuminates Emissions.
Tags: lasers
Neat idea, but there is a little obvious irony here… Smoke stack is result of power plant which powers laser. The commentary on pollution itself causes pollution, and by the brightness of that beam, not a trivial amount… .
Given the abysmal energy efficiency (<0.01%) of most lasers, I definitely see your point.
[...] in Helsinki by outlining the emissions of a local power plant via green laser. As a previous commenter points out, there’s a bit of irony present due to the high-powered laser’s high-power [...]
[...] die sogenannte “Green Cloud” mittels eines grünen Lasers projiziert. Wie der Mighty Ohm – Blog erkannte, müsste es sich mit der Installation wahrlich um das weltweit größte Oszilloskop [...]
