Tag Archives: geiger
How to use Geiger Bot with the MightyOhm Geiger Counter
Geiger Bot is an iOS application that allows you use your iPhone or iPad as a sophisticated display for an ordinary Geiger counter. It works with most Geiger counters that make an audible “click” for each event or count that is detected.
Here’s how to get your MightyOhm Geiger Counter working with Geiger Bot. These instructions were tested with an iPhone 4, but should work with other iOS devices (iPads and other versions of the iPhone).
Continue reading How to use Geiger Bot with the MightyOhm Geiger Counter
Feed your Geiger: Cheap and Readily Available Radioactive Test Sources
Want to check if your freshly-assembled MightyOhm Geiger Counter kit is working? You’ll need something radioactive! But why pay over $100 for a professional test source when there are plenty of cheap and readily available radioactive items available at your local antique store or online?
Continue reading Feed your Geiger: Cheap and Readily Available Radioactive Test Sources
