Let’s say you are designing a printed circuit board in Eagle, and you need to place a component that you’ve never used before. In Eagle, before you can use a new component, you need a land pattern, a schematic symbol, and a mapping between them to fully define the part. Often, you can search through Eagle’s included libraries and find what you need (or something close enough). But what if that fails?
The symbol and pin definitions are usually pretty easy – just copy the datasheet. The hard part is the land pattern: the collection of copper traces, soldermask openings, silkscreen, and other features that define the part on the PCB.
To come up with a land pattern, you usually have a few options:
- Someone else may have done you a big favor by creating a part definition and uploading it to the Eagle library directory. Caveat: Use it at your own risk. Surface mount parts tend to be particularly hard to use right out of the box – often someone else’s land pattern won’t even pass your DRC. Whose process were they using, anyway??
- Look through the datasheet for the part to try and find a recommended land pattern. (Good luck! Increasingly these are not included, but may be somewhere else on the manufacturer’s website. Google is your friend!)
- Take a guess based on the geometry of the part, assuming you have a mechanical drawing or a physical sample somewhere.
- Skip 1-3 and use an IPC-7351 land pattern generator.
IPC-7351 is a standard for printed circuit board land pattern designs. The standard attempts to, well, standardize land patterns to try to discourage every PCB designer from having his or her own custom library of land patterns. IPC takes known good land patterns and combines them with accepted manufacturing tolerances to produce a land pattern that will work for most people most of the time. Increasingly you will see references to IPC-7351 in datasheets instead of a land pattern drawing, so access to the standard is becoming more important over time.
Cool, right? Well, the bad news is that while you can browse through the table of contents/introducton for free, downloading the standard costs big bucks.
Fortunately, PCB Matrix has a free IPC-7351 Land Pattern Calculator (direct download link here) that you can use to generate land patterns based on the standard. You don’t need to own a copy of the standard to benefit from it.
The calculator is somewhat tricky to use but if you click the right buttons you can get something like what is shown below (click to enlarge).
X and Y are the dimensions of the recommended pads for an 8-lead Thin SOT-23, which happens to be the package for the LT3464.
With this information, you can return to Eagle and create a land pattern for your device. PCB Matrix will also sell you premade Eagle libraries, but from their site it was not clear how much they cost. Based on their other products, my guess is several hundred dollars and a yearly maintenance contract – I’ll draw my own, thanks.
Unfortunately, the calculator is Windows only, so Mac guys like me need to use VMware Fusion or similar to use it. Can someone create a web version, please?
For those looking for this landpattern generator, Mentor Graphics bought the company and started charging for it. I’m waiting for information on pricing, but being Mentor I’m not expecting to be able to pay for it unless I sell my first-born.
Oh no! That’s really unfortunate as I used the old free tool quite a bit. What a shame that it is no longer available free without a 30-day trial period!
I asked about pricing… The “Eagle version” is $1,250 plus “support”!!!
Makes me want to buy the standard itself and spend a couple days writing the trivial scripts necessary to generate the footprints myself, then publish them for free as a library….
I worked out the equations for standard rectangular SMD components, like resistors and chip caps. Most of the time I get the same results as the calculator, but sometimes their results are slightly off (could be rounding errors or manually tweaked parts in the libraries, not sure). I never looked into more complex parts like TQFPs but it should be possible to come up with a calculator based on the IPC guidelines…
My local eagle retailer makes a tool for dumping IPC7351 packages into eagle. I’ve never used it, and it’s a few hundred dollars, but it’s out there.
http://www.eaglecentral.ca/forums/index.php?t=msg&goto=59648&S=6d85bdd68739e19e4eccd5e6f2ee7877#msg_59648
I haven’t used Wine (or Crossover) before, but maybe this would be a good opportunity to play with them. I hate having to fire up VMWare just to use simple tools like these, particularly because every time I do, XP needs to update something and nags me about having to restart. Argh!
Did you try wine? I think there is a mac version. Most any simple GUI app like this will run under wine.
