Teleport allows keyboard/mouse sharing between Macs
June 29th, 2009 by Jeff
Teleport is a program for OS X that lets you share one keyboard and mouse between multiple computers – very handy for when you want to turn a macbook into a makeshift second display for your Mac desktop. Before I discovered teleport, I was using synergy, which achieves almost the same result but requires an open Terminal window to launch and use it (synergy’s daemon functionality is broken in Leopard). Teleport has some other advantages over synergy, including drag and drop file support (really cool!) and working mouse-wheel scrolling.
I initially had some problems with a short delay when moving the mouse from my desktop to the remote display, but I quickly resolved this by making a couple changes to the teleport configuration:
- Uncheck “Show bezel when controlling shared Mac” in the teleport control panel options, as shown below. This actually makes a noticeable difference.
- Disable the switch animation by executing this command in a Terminal window:
defaults write com.abyssoft.teleport showSwitchAnimation NO
Now my pointer moves almost instantaneously from one display to the next, even with one machine on Wi-Fi. Curiously, I only had to make the changes on the server side, I left the client machine preferences alone.
Hopefully this will help other folks who are having the same issue.
This looks much better than synergy for mac-mac, but alas I need to share with Windows boxen (blush) so I’m stuck with Synergy for the nonce.
Robert – Thanks for pointing that out! Cross platform support certainly is a big plus for synergy, if only the Mac client was a little more polished I would still be using it.
